Today Only,
We offer portable performance with a huge 17.3" screen, 3GB of RAM, 320GB Hard drive and many more features for a fantastically reduced price.
Corsair Vengeance memory modules provide users with outstanding memory performance and stability.
Samsung R730 17.3" LED Intel Dual Core T4500, 3GB RAM, 320GB HDD, DVD-RW, Win7 Home Premium @ £347.99 inc VAT
If you want a laptop that will deliver top-drawer performance without the top-drawer price tag, then take a look at the Samsung R730. It’s powerful, and it won’t empty your pocket.
If you’re into music and movies, or you want to multitask all your favourite applications without your laptop lagging behind then the R730 is for you. It’s got a powerful Pentium Dual Core processor alongside a huge 3GB RAM, so it’ll make light work of your heaviest tasks; it’s ideal for students and home users who want a machine that covers every base.
Great performance is nothing without great visuals to match and the R730 definitely doesn’t disappoint. The stunning 17.3” high-definition LED screen turns this laptop into your own portable cinema. Wherever you go, you can enjoy your favourite films in unprecedented detail; sit back, relax, and enjoy.
When the movie’s done and you fancy some music, the R730 will continue to impress. The SRS 3D Sound technology will give your songs a whole extra edge, and the massive 320GB hard drive will ensure you’re never struggling with space to store them.
Samsung understand that in today’s modern digital world, the connectivity of your laptop is key. The R730 comes with a HDMI port, so you can hook it straight up to your big screen TV and use that as your monitor. It’s got wireless technology and an integrated webcam too, so you’ll never be more than a few clicks away from your online social life.
Inject your life with some Samsung style, and enjoy amazing power at an affordable price, with the Samsung R730 laptop.
Features:-
- Intel Pentium Dual Core T4500 2.3GHz (Dual Core)
- 3GB DDR3 SDRAM - 1066 MHz
- 17.3" Superbright LCD
- 320GB HDD
- 17.3' TFT (1600x900 Resolution)
- DVD±RW (+R double layer) / DVD-RAM Optical Drive
- Intel GMA X4500 Dynamic Video Memory Technology 5.0 Graphics
- Integrated Webcam
- Microsoft Windows 7 Home Premium
- 6 Cell Battery (upto 4hrs battery life)
- 2.84kg weight
- HDMI Port
- 12 Month Warranty - Brand new sealed product
Only £347.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £77.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £77.99 inc VAT.
ORDER NOW
Features:-
- 320GB HDD
- Integrated Webcam
- 2.84kg weight
- HDMI Port
ORDER NOW
- Lifetime Warranty
ORDER NOW
