Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. On the front of the case is another innovation dubbed BitFenix ICON™ - a programmable display that can be customized with a simple drag and drop interface, making it simple to personalize the look of your case whenever inspiration strikes. Despite its slim 160 mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 50 mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow
design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screw-less side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
View the whole range here
BitFenix Pandora Micro-ATX Case - Silver Windowed @ £94.99 inc VAT
Specifications:-
- Material: Aluminum, Steel, Plastic
- Dimensions: 160 x 420 x 465
- Form Factor: Micro ATX, Mini-ITX
- LCD: 2.4" TFT, 240 x 320
- 3.5" Driver Bays: 2
- 2.5" Driver Bays: 3
- Cooling top: 120mm x 1 (included)
- Cooling Front: 120mm x 2 (1 included)
- PCI Expansion slots: 5
- Front Panel: USB 3.0 x 2, HD Audio
- Power Supply Support: ATX, up to 180mm in length
- USB 3.0 x 2, HD Audio
Only £94.99 inc VAT.
ORDER NOW
BitFenix Pandora Micro-ATX Case - Black Windowed @ £94.99 inc VAT
ORDER NOW
Specifications:-
ORDER NOW
ORDER NOW
