Tony Hawk's Pro Skater HD
No graphics options = no purchase for pc. That is lazy we need AA as at least an option. 2560x1600 should also be selectable.
its takes less than two minutes to sort out the graphics options in the config file.
Personally i think it looks good and runs really well for an 9 quid game.. I will post some screenies later if you want.
Almost bought it as soon as it came out, but then I saw this thread. In my view, by buying games which are simply shoddy ports, it tells the developers that people are happy to buy those ports, so they won't put any extra effort in the future. If they do patch proper settings in the future then I'll happily put my money down.
Sadly that isn't what they'll read from it, they'll see that people aren't interested in these sort of games on PC :(
I was also gonna buy it, but I have decided against it until they patch it a bit, as I think people will kick up enough fuss for them to add in proper setting selection menus.
Is this really classed as a port though?
Its running on the Unreal engine which is a PC engine primarily..
looking through all the files it would seem the porting is more the other way to consoles / IPADS etc...
I purchased this as I loved the original on the PS one. Gotta say I'm addicted all over again! It runs really well (60fps 1920x1200) and takes two seconds to change the config file. If you're a graphics whore who needs AA and AF just create a profile in your video card settings. Apart from the lack of multiplayer I'm really not sure what everyones moaning about :confused:
People tend to not really know what they're talking about when they say "CONSOLE PORT" anyway.
Actual "porting" very rarely happens in the way people imply, what does happen is a proper PC version is made, but no effort is put in to optimising it for PC, which results in things like no graphics options, or poor controls, low resolution/quality assets and various other things.
1920x1200 You got this working without black bars? could only get mine to 1920x1080 without bars top and bottom by just editing cfg.
Loving it as well so far and for £9 quid you cant complain. would have been far superior with multiplayer but will no doubt grab the ps3 version for that.
New DLC for this tomorrow apparently (4th Dec), 3 maps from thps3 (LA,Canada,Airpot) and some new skaters. $4.99.. dont know how much that will be our side of the pond
