Total novice help needed.
26 Dec 2020
Hi we have a Firefly essential intel core i5 10400F GeForce GTX 1660 super. Will it have Wi-Fi access built in or do I need a card? Also will the drivers etc etc already have been installed when it was built?
18 Oct 2002
West Midlands
Should tell you in the specifications sheet when you bought it.
If you boot up the computer, and type network in to the start menu, then to see if it lists WiFi networks that will also give you a clue if it does have it and if the drivers are installed.
23 Aug 2012
I just had a quick look at that system on the OCUK website, and a Wi-Fi adapter is an optional extra when you order the system. So if you didn't add one when you placed the order, it won't have one built in.
Probably best to ask OCUK customer service about the drivers, but I'd be a little suprised if they weren't already installed.
