- 22 Apr 2014
TP-Link are launching two new AC wireless PCI-e network adaptor cards. I hope to see them in stock by the end of Feb. I will keep you all updated with lead times on this post.
TP-Link Archer T8E AC1750 Wireless Dual Band PCI Express Adapter @ £49.99 inc VAT
Highlights:
802.11ac - The Next Generation of Wi-Fi
TP-LINK’s Archer T8E comes with the next generation Wi-Fi standard – 802.11ac, 3 times faster than wireless N speeds. With 1300Mbps wireless speeds over the crystal clear 5GHz band or 450Mbps over the 2.4GHz band, the Archer T8E is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
AC1750 Wireless Speed
The 5GHz 1300Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4GHz 450Mbps Wi-Fi for normal use such as web surfing
The Best of Both Bands
TP-LINK’s Archer T8E is an AC1750 Wireless Dual Band PCI Express Adapter giving users the ability to access crystal clear 5GHz connections or legacy 2.4GHz connections to upgrade their PC’s wireless capabilities to operate with new 5GHz band wireless networks, while ensuring that they can still access legacy 2.4GHz band wireless networks.
WPA/WPA2 Encryptions – Advanced Security
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders
Features:
Only £49.99 inc VAT.
ORDER NOW
TP-Link Archer T9E AC1900 Wireless Dual Band PCI Express Adapter @ £59.99 inc VAT
Highlights:
TP-LINK’s Archer T9E comes with the next generation Wi-Fi standard – 802.11ac, 3 times faster than wireless N speed. With 1300Mbps wireless speeds over the crystal clear 5GHz band or 600Mbps over the 2.4GHz band, the Archer T9E is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
AC1900 Wireless Speed
The 5GHz 1300Mbps is perfect for HD video streaming and lag-free online gaming, while using 2.4GHz 600Mbps Wi-Fi for normal use such as web surfing.
TP-LINK’s Archer T9E is an AC1900 Wireless Dual Band PCI Express Adapter, giving users the ability to access crystal clear 5GHz connections or legacy 2.4GHz connections to upgrade their PC’s wireless capabilities to operate with new 5GHz band wireless networks, while ensuring that they can still access legacy 2.4GHz band wireless networks.
Beamforming Technology for Efficient Wi-Fi
Archer T9E utilizes beamforming technology to receive more directional Wi-Fi signals for improved performance.
WPA/WPA2 encryption standards ensure your wireless connection is safe from intruders.
Features:
Only £59.99 inc VAT.
ORDER NOW
Highlights:
- Ultra-fast 1750 (1300+450)Mbps wireless speed with 802.11ac
- Dual Band connections for lag-free HD video streaming and gaming
- 3T3R MIMO technology provides robust high-bandwidth wireless transmission
Features:
- Supports 802.11ac standard- The next generation of Wi-Fi
- Maximum speed up to 5GHz 1300Mbps or 2.4GHz 450Mbps
- Backward compatible with 802.11 a/b/g/n products
- Supports ad-hoc and infrastructure mode
- Supports Windows 8.1/8/7/XP 32/64bit
- Easy Wireless Configuration Utility
ORDER NOW
Highlights:
- Easy Installation – Upgrade your desktop system easily by plugging the Archer T9E Wi-Fi adapter into an available PCI-E slot.
- Hi-Speed Wi-Fi – Up to 1900Mbps Wi-Fi speeds (1300Mbps on 5GHz band or 600Mpbs on 2.4GHz band)
- 802.11ac Dual Band – 3 times faster than the 802.11n standard, perfect for hi-intensity network usage
- Backward Compatibility – With support for 802.11 a/b/g/n standards
- Beamforming Technology – Receives more directional Wi-Fi signals, improving speed and reliability
- Ultimate Range – 3 external antennas ensure a greater range of Wi-Fi connection and stability
Features:
- Simply slot the adapter into any free PCI-E socket in your desktop PC and connect to an available Wi-Fi network
- Maximum wireless speeds of up to 1900Mbps with 1300Mbps at 5GHz or 600Mbps at 2.4GHz band, ideal for HD streaming, online gaming and large file downloads
- Supports 802.11ac – Wi-Fi technology that is 3 times faster than 802.11n
- 3 external antennas provide ultimate Omni-Directional wireless coverage, delivering a stable connection to your Wi-Fi network
- Utilizes Beamforming technology to receive more directional Wi-Fi signals, enhancing the reliability of the wireless connection
- Heat Sink dissipates heat to help increase performance and improve stability
- Selectable 2.4GHz and 5GHz bands to avoid wireless signal interference
- Supports routers utilizing 802.11 a/b/g/n Wi-Fi standards
- Bundled management utility offers easy administration to control your Wi-Fi network
ORDER NOW
