Right.
Traffic lights, 2 main sorts, Puffin which are all over the play which arent specifically designed for pedestrians to cross (Ie they have to buttons to push) Right?
Toucan, Same as normal traffic lights, but they have a button and bikes can cross on them?
zebra, has a button, people only? Has zebra-esque strips on the road near them.
Which way to traffic lights go for drivers and pedestrians? I know red is stop (if its safe to do so) REd, steady amber then green? When does amber flash? When its going from green to red?
Motor way studs
I assume they are just red and white? Red on the left just like an airplane wing, then white?
Also, stopping distances and braking distances, which is the one where you have to think? Whats the formula for working it out?
Motor way studs
