** TRUE KINGS OF 4K: UK's LARGEST RANGE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I've being further expanding our range of 4k monitors, check them all out:
Acer 4k2k CB280HK 28" Gaming Widescreen LED Monitor - Black @ £349.99 inc VAT
The Acer CB0 Series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Specification:
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (60Hz), 1x DVI and 1x HDMI
- VESA: 100x100mm
- Speakers: Yes
- Warranty: 2yr
Only £349.99 inc VAT.
ORDER NOW
Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £539.99 inc VAT
nonl2br
<p>
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
</p>
<p>
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
</p>
<p>
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
</p>
<p>
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
</p>
<p>
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
</p>
<p>
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
</p>
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</center>
<br><br>
<p>
<h1>Features:</h1>
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.<br>
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.<br>
- ComfyView technology – the non-glare panel reduces reflection from light source.
</p>
<p>
<h1>Specification:</h1>
- G-Sync Technology<br>
- Flicker-less Technology<br>
- Height Adjust stand with tilt, swivel and pivot<br>
- Display Screen Size: 28" (70.8cm)<br>
- Aspect ratio: 16:9<br>
- Panel Type: TN<br>
- Brightness: 300cd/m2<br>
- Contrast Ratio: 1000:1 (Typ)<br>
- Dynamic Contrast Ratio: 10,000,000<br>
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br>
- Response Time: 1ms (GTG)<br>
- Colurs: 16.7M<br>
- Bits: 8 bits+HiFRC<br>
- Viewing Angle (H / V ): 170 ° / 160 °<br>
- Connectivity: 1x DisplayPort 1.2 (60Hz)<br>
- USB Hub 3.0: Yes (1up, 4down)<br>
- VESA: 100x100mm<br>
- Speakers: No<br>
- Warranty: 2yr
</p>
Only £539.99 inc VAT.
ORDER NOW
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £379.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Panel Type: TN
- Dynamic Contrast Ratio: 80,000,000
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £379.99 inc VAT.
ORDER NOW
Asus PB287Q 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £443.99 inc VAT
Asus enter the price war with their gaming 28" 4k monitor, just like other models sporting an impressive specification with a fast response 1ms TN panel, 60Hz over DisplayPort. The Asus also has some innovations of its own such as a flicker free backlight to help reduce any flicker along with a fully adjustable stand.
Experience games in such detail and realism like never before at 4k resolution, just ensure you have the lastest graphics cards and ideally in multi-GPU configurations to get the best from your 4k panel.
Specification:-
- Panel Type: TN
- Flicker FREE backlight
- PIP/PBP Support
- Connectivity: 2x HDMI, 1x DisplayPort
- Speakers: Yes
- Warranty: 3yr
Only £443.99 inc VAT.
ORDER NOW
Asus PQ321QE 4K Super-High Resolution Widescreen Monitor - Black @ £1,619.99 inc VAT
Games look absolutely out of this world when played in 4k, yes you will need some serious graphics card horsepower but for the visuals it is worth every penny.
The ASUS PQ321QE True 4K UHD monitor provides stunning visuals with an ultra-high definition 3840 x 2160 resolution. The anti-glare 31.5-inch LED-backlit UHD display has a 16:9 aspect ratio and 140 pixels per inch (PPI) for highly-detailed visuals.
By doubling the number of horizontal and vertical pixels, the PQ321QE True 4K UHD monitor gives you every bit of detail, far surpassing that of a Full HD monitor. With four times the resolution of Full HD (FHD) and over 8 million pixels, experience larger screen real estate and clarity you have to see to believe.
The ASUS PQ321QE True 4K UHD monitor is a 10-bit RGB panels that delivers more natural transitions between different hues and offers a more flawless image than ever before.
The ASUS PQ321QE True 4K UHD monitor is built with an anti-glare Indium Gallium Zinc Oxide (IGZO) panel rather than traditional amorphous silicon. The IGZO panel supports much smaller transistors than amorphous silicon, which allows for much smaller pixels and much better detail. Couple with an ultra-wide 176-degree viewing angles on both vertical and horizontal planes, get a pristine image from virtually any angle. What’s more, the IGZO panel supports increased pixel transparency and reduced current leakage for increased energy savings.
The ASUS PQ321QE True 4K UHD monitor features DisplayPort to connect to your PCs simultaneously. Built-in 2W stereo speakers simplify free space from needing separate speakers for a complete audio visual experience. The thinnest 4K monitor available, the ASUS PQ321QE True 4K UHD monitor measure only 35mm at its thickest point, showcasing a modern design fit for anywhere in the home or office.
Features:-
- 31.5-inch 4K display with ultra-high definition (UHD) 3840 x 2160 resolution and 140 pixels per inch (PPI) for impeccable visuals
- An anti-glare, LED-backlit IGZO display delivers crisp, precise images with energy efficiency with an ultra-wide viewing angle
- DisplayPort and built-in dual 2-watt stereo speakers
- The thinnest 4K monitor available, the PQ321Q is wall-mountable with full tilt, swivel, and height adjustment
Specification:-
- Panel Size: 31.5" 16:9 Widescreen
- Panel Type: IGZO / LED Backlight
- True Resolution: 3840 x 2160
- Pixel Pitch: 0.182mm (140ppi)
- Brightness: 350cd/m
- Contrast ratio: 800:1
- Display Colours: 1.07 Billion (10-bit)
- Viewing Angle: 176 / 176
- Response Time: 8ms (Gray-to-Gray)
- Trace Free Technology
- HDCP Support
- Colour Temperature selection
- Gamma Adjustment
- 2W x 2 Stereo Speakers
- Connections: DisplayPort, RS-232C, PC audio line-in, Earphone out
- Power consumption: 93W
- Kensington Lock
- Dimensions with stand: 750 x 489 x 256 mm (WxHxD)
- Dimensions without stand: 750 x 441 x 35 mm (WxHxD)
- Weight: 13kg
- Warranty: 3yr
Only £1,619.99 inc VAT.
ORDER NOW
BenQ BL3201PT 32" 4k 60Hz Professional Widescreen LED Monitor - Black @ £899.99 inc VAT
The BL3201PT, a stunning 32”W display built with IPS technology and the latest 4K2K ultra-high-definition resolution, as a part of its continued effort to support the visual-intensive work required in the fields of CAD/CAM, animation, video editing and graphics arts. So professionals with a meticulous eye for detail can work with perfect precision and achieve high productivity.
Designed to meet the rising demands for large-sized viewing and ultra-high definition, the BL3201PT boasts a 32”W 4K2K display built with BenQ’s advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 300% working space to enhance their work efficiency and productivity.
Every color is delivered with the finest precision in every detail and at every possible viewing angle for a great viewing experience. With a 10-bit panel that renders more than one billion hues, every image is displayed with the richest, liveliest colors.
Professional CAD/CAM engineers and designers work with extremely detailed information, making superb display clarity and color accuracy absolutely vital for ensuring design precision. BenQ’s BL Series offers a number of display solutions for maximized display performance, including the CAD/CAM Mode to bring out even the smallest details to view for Pro/E, SolidWorks, AutoCad, CATIA or other CAD/CAM software. Recognizing the multi-tasking and collaborative nature of the work, thoughtful features that support a wide range of viewing options are included to ensure high productivity can be preserved while users run a number of tasks simultaneously or compare and discuss design work with colleagues.
For clearly distinguished details in complicated object wireframes, switch on the CAD/CAM Mode to alter the monitor’s color and contrast settings to view highly detailed graphic information without ever missing a line again.
SolidWorks Certification Being a Solidworks Solution partner translates to display excellence certified to be of professional standard for CAD/CAM software users.
Professional animators work to breath life into moving art, making even the tiniest detail paramount to delivering lively creations. To answer the visual demands of the most sophisticated animators, BenQ BL Series monitors give you uncompromising accuracy consistency for displaying every shade of colors through a wide range of optimized image calibration settings, including the brightness-enhancing Animation Mode. There is also a multitude of viewing features incorporated into the monitors to simultaneously display all the information needed for making color adjustments. So no detail can escape the eyes of its creator!
To make distinguishing detailed textures in darkened areas easier, BenQ developed the Animation Mode to enhance the brightness in dark areas of the artwork – without overexposing bright areas. This allows animators to fine-tune their animation creation effortlessly.
Color accuracy and a clear line of view are of utmost importance for anyone working in the field of professional video editing. BenQ BL Series offers a wonderful range of 100% sRGB monitor with a resolution of QHD and 4K2K UHD to give you crisp and clear viewing quality accompanied by true, lifelike colors. The large viewing space combined with optimal viewing prevision give video editors full access to all the editing tools, applications and images they need to work with. So they can perform every task with maximized efficiency.
A high-quality monitor with high resolution, high color accuracy and fidelity and a wide range of high-speed connectivity options is what makes a perfect companion for professionals in the graphic arts industry, including graphic designers, retouchers and photographers. Featuring the highest resolution at 3840x2160 4K2K with 100% sRGB and BenQ’s advanced IPS technology, the BL Series showcases consistent, reliable color results with every detail precisely rendered for a brilliant viewing experience from virtually every perspective. A variety of connectivity and view options also enables users to work with multiple devices and perform complex multi-tasking work with ease.
Designed for professional designers accustomed to work with a square monitor, this feature allows them to work with nearly two 19” displays by dividing a 32” BL Series monitor screen into two 4:3 or 5:4 viewing areas – which can be further resized from 19”S to 30”W in size using the Display Mode feature. For enhanced convenience and productivity, the PIP/PBP feature allows you to compare two or more pictures as well as display drawings from two PCs simultaneously for a more efficient work discussion.
The Display Pilot software is a total solution package for designers seeking to customize their display. You can assign specific color modes to frequently used software applications on your computer with Application Tuning, and Display Pilot software will automatically apply the preset color mode to the matching software application in use. Other features that can also be accessed through Display Pilot include Auto Pivot, Desktop Partition, PIP/PBP and other OSD settings such as brightness adjustments.
Auto Pivot detects the movement of the monitor and dynamically rotates the contents displayed for flexible landscape or vertical viewing without utilizing Windows or graphic card settings. The BL Series are newly upgraded with the incorporation of BenQ’s proprietary Flicker-free Technology to eliminate backlight flickering at all brightness levels and effectively reduce eye fatigue. Conventional LCD screens flickers 200 times per second. The flickers may not be detectable by your eyes but they can certainly feel the flickering. So it is important to relieve your eyes from the stress caused by a flickering screen – and keep them nice and fresh when you are working on new designs.
Features:-
- 32”W Large Screen 3840x2160 UHD Resolution
- 100% sRGB Color Space
- Display Pilot Software
- OSD Remote Access
- CAD/CAM Mode and Animation Mode for Precision Design
Specification:
- Display Screen Size: 32"
- Panel Type: IPS
- Brightness: 350cd/m2
- Dynamic Contrast Ratio: 20,000,000
- Response Time: 4ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 178 ° / 178 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Mini-DisplayPort (60Hz), 1x DVI-DL
- USB Hub: Yes (USB3.0)
- Speakers: Yes (2x 5W Stereo)
- VESA: 100x100mm
- Height adjust, pivot, swivel stand
- Warranty: 2yr
Only £899.99 inc VAT.
ORDER NOW
Dell UltraSharp UP2414Q 24" 4K Widescreen LED Monitor - Midnight Grey @ £479.99 inc VAT
See a new level of clarity in your creations with a 24" monitor featuring Ultra HD resolution and our highest pixel density yet. Whether it’s video editing, CGI animation or application and game development, the DellTM UltraSharp 24 Monitor – UP2414Q gives you an up-close-and-personal view. PremierColor technology delivers vivid, true-to-life color and professional tools for detailed projects.
Features:-
- Get four times the resolution of Full HD and see the finest details with ultra-high pixel density.
- PremierColor provides true color accuracy as well as 99% Adobe RGB and 100% sRGB coverage.
- Ultrawide viewing angles, plus tilt, swivel, pivot and height adjustment features enable an uninhibited view.
Specification:-
- Diagonally Viewable Size: 60.47 cm
- 23.8" (23.8-inch wide viewable image size)
- Aspect Ratio: Widescreen (16:9)
- Panel Type, Surface: In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 3840 x 2160 at 60 Hz (DP1.2) / 3840 x 2160 at 30 Hz HDMI
- Contrast Ratio: 1000: 1 (typical) 2 Million:1 (Max) (Dynamic Contrast Ratio)
- Brightness: 350 cd/m2 (typical)
- Response Time: 8 ms (gray to gray)
- Viewing Angle: (178° vertical / 178° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100%
- 1.07 Billion colors (8 Bits +AFRC)
- Pixel Pitch: 0.137 mm
- Pixel Per Inch (PPI): 185
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Connectivity: 1x HDMI connector, 1x Mini DisplayPort, 1x DisplayPort (version 1.2a), 4x USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream, 1 Media Card Reader
- Size and Weight: Dimensions with stand (H x W x D): 14.61" ~ 19.75" (371.1 mm ~ 501.7 mm) x 22.40" (569.0 mm) x 7.56" (192.0 mm)
- Dimensions without stand (H x W x D): 13.33" (338.5 mm) x 22.40" (569.0 mm) x 2.22" (56.3 mm)
- Weight (panel only - for VESA mount): 4.8 kg (10.58 lbs)
- Weight (with packaging): 10.0 kg (22.05 lbs)
- Warranty: 3yr
Only £479.99 inc VAT.
ORDER NOW
Dell P2815Q 28" 4K Widescreen LED Monitor - Midnight Grey @ £329.99 inc VAT
The moment you turn it on, you’ll see the difference. With such incredible clarity on an expansive 28-inch screen, the DellTM 28 Ultra HD Monitor - P2815Q delivers an impeccable performance that defies its mainstream price.
Whether you scrutinize spreadsheets, manage marketing plans, or review videos and photos, the Dell 28 Ultra HD Monitor - P2815Q delivers a reliable performance for every task. Boost your productivity with a wide range of connectivity and viewing options.
With our Premium Panel Guarantee1 and the latest environmental compliance, you’ll enjoy peace-of-mind and minimized downtime.
Features:-
- Affordable Ultra HD (3840 x 2160): Experience four times higher resolution than Full HD for pin sharp details.
- Excellent picture quality: With high dynamic contrast ratio and brightness.
- Expansive display: Plenty of space to see all of your applications across an expansive 28-inch display.
Specification:-
- Diagonally Viewable Size: 28.0" (28-inch wide viewable image size)
- Panel Type, Surface: TN
- Optimal resolution: 3840 x 2160 at 30 Hz
- Brightness: 300 cd/m2 (typical)
- Response Time: 5 ms (typical)
- Viewing Angle: (160° vertical / 170° horizontal)
- Color Support: 1.073 billion colors
- Pixel Pitch: 0.16 mm
- Connectivity: 1x DisplayPort, 1x Mini DisplayPort, 1x HDMI (MHL), 1x DisplayPort out (MST), 1x USB Upstream, 4x USB 3.0 ports - Downstream (3 at the bottom, 1 up to 1.5A charging port with BC1.2 compliance devices at the back)
- Audio Output: Dell Speaker Bar AC511 (optional)
- Height-adjustable stand, pivot, tilt , swivel and built in cable-management
- Flat Panel Mount Interface: VESA (100 mm)
- USB 3.0 Super-Speed Hub (with 1 USB upstream port and 4 USB downstream ports, including 1 up to 1.5A charging port with BC1.2 compliance devices)
- Dimensions with stand (H x W x D): 17.14" ~ 21.67" (435.3 mm ~ 550.3 mm) x 26.04" (661.3 mm) x 8.03" (204.1 mm)
- Dimensions without stand (H x W x D): 15.03" (381.7 mm) x 26.04" (661.3 mm) x 2.21" (56.2 mm)
- Preset Display Area(H X V): 620.9 mm x 341.3 mm 24.45" x 13.44"
- Weight (panel only - for VESA mount): 5.19 kg (11.42 lbs)
- Weight (with packaging): 11.12 kg (24.47 lbs)
- Warranty: 3yr
Only £329.99 inc VAT.
ORDER NOW
Dell UltraSharp UP3214Q 31.5" Widescreen LED 4K Monitor - Midnight Black @ £1,399.99 inc VAT
See your work in stunning Ultra HD clarity on our largest DellTM UltraSharp monitor featuring high pixel density and exceptional color accuracy.
Whether it’s video editing, CGI animation or application and game development, the Dell UltraSharp 32 Monitor – UP3214Q lets you hone in on the fine details and give your work the attention it deserves. Featuring PremierColor, the UP3214Q offers superb color accuracy and high-end professional features.
Features:-
- Ultra HD 3840 x 2160: Get four times the resolution of Full HD and see the finest details with ultra-high pixel density.
- Vivid, accurate and consistent color: With PremierColor, your monitor provides superb color accuracy and 99% AdobeRGB and 100% sRGB coverage.
- Expansive display: Multitask with plenty of space to see all of your applications across an expansive 31.5" display.
- See more in Ultra HD 3840 x 2160. That’s four times the resolution of Full HD.
- With extremely high pixel density, the tiniest details in videos and images are revealed, providing a whole new level of clarity.
- Do more with a 31.5" screen, giving you ample space to open multiple applications.
- Get a clear and consistent view with an ultra-wide 176°/176° viewing angle.
- Keep your virtual workspace tidy with the Dell Display Manager’s Easy Arrange feature that lets you neatly display windows side by side.
Specification:-
- Diagonally Viewable Size: 80.1 cm
- 31.5" (31.5-inch wide viewable image size): Aspect Ratio:
- Widescreen: 16:9
- Panel Type, Surface: IGZO LCD, In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 3840 x 2160 at 60 Hz (DP1.2*), 3840 x 2160 at 30Hz HDMI
- 2 Million:1 (Max) (Dynamic Contrast Ratio)
- Viewing Angle: (176° vertical / 176° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100%, 1.074 Billion colors (10 Bits)
- Pixel Pitch: 0.182 mm
- Pixel Per Inch (PPI): 140
- 1x Media Card Reader
- Stand: Height-adjustable stand, tilt, swivel and built in cable-management
- Dimensions with stand (H x W x D): 19.0" ~22.5" (482.6 mm ~ 572.4 mm) x 29.5" (749.9 mm) x 8.4" (214.0 mm)
- Dimensions without stand (H x W x D): 17.5" (444.6 mm) x 29.5" (749.9 mm) x 2.0" (51.5 mm)
- Warranty: 3yr
Only £1,399.99 inc VAT.
ORDER NOW
Iiyama ProLite B2888UHSU-B1 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black @ £419.99 inc VAT
Iiyama's ProLite B2888UHSU 4K monitor offers a 60Hz refresh rate and a 1ms response time making it ideal for gamers and incorporates a special 1 chip solution to help reduce input lag. Also featuring blue light reduction to help reduce backlight bleed and flicker free technology. Iiyama have gone out of their way to offer a monitor with great features and it even includes a height adjust stand with VESA mount ability.
Specification:-
- Panel Type: TN
- Connectivity: 2x HDMI (30Hz), 2x DisplayPort (60Hz), 1x DVI, 1x Analogue
- USB Hub: Yes
- Speakers: Yes
- PIP, POP
- Height adjust stand
- Blue light reducer
- Flicker Free Technology
- Reduced input lag (1 Chip Solution)
- Warranty: 3yr
Only £419.99 inc VAT.
ORDER NOW
LG Flatron 31MU97 31" True 4K 60Hz Professional WideScreen LED Monitor - Black @ £1,099.99 inc VAT
When most consumers refer to ‘4K’, they’re actually referring to the UHD (Ultra High Definition) resolution of 3840 x 2160. This is, after all, the most common ‘4K’ resolution. It also maintains the common 16:9 aspect ratio and provides quite an enjoyable experience. The LG 31MU97 features a 4096 x 2160 resolution which is also referred to as ‘Digital Cinema 4K’ due to its use as the dominant 4K resolution by the DCI (Digital Cinema Initiatives). The monitor features LG’s robust ‘business-like’ stand which offers tilt and height adjustment but can’t be pivoted or swivelled.
This display uses a 31” AH-IPS panel (LM310UH1-SLA1) with a 4096 x 2160 resolution (17:9 aspect ratio) and 60Hz refresh rate. This features a very light matte (‘semi-glossy’) screen surface and is designed to provide accurate and consistent colours in both the sRGB and Adobe RGB colour spaces. It uses a flicker-free (‘Flicker Safe’ – PWM free) GB-LED backlight to provide this wide colour gamut (100% sRGB and over 99% Adobe RGB). The monitor is also factory calibrated for both of these colour spaces and features true 10-bit colour reproduction. It can be user-calibrated with the ‘LG True Color Pro’ software as well. ‘Reader’ modes also feature, which are ‘Low Blue Light’ settings allowing the user to select white point targets such as 3882K, 4300K or 4616K to cut down on the blue light emission.
The monitor features a wide range of ports, including; DisplayPort, Mini DisplayPort, 2 HDMI ports, 3 USB 3.0 ports and a 3.5mm headphone jack. The native resolution is supported at 60Hz over DP or MiniDP but only at 30Hz over HDMI. 5W stereo Maxx Audio speakers also feature, which seems to be a favourite on higher-end LGs at the moment. The included stand can be removed to reveal 100 x 100mm VESA holes.
Specification:
- Display Screen Size: 31"
- Aspect ratio: 17:9
- Panel Type: AH-IPS
- Resolution: 4096x2160 (Only over DisplayPort at 60Hz)
- Response Time: 5ms (GTG)
- Speakers: Yes (5W Stereo)
- VESA: 100x100mm
- Warranty: 2yr
Only £1,099.99 inc VAT.
ORDER NOW
NEC MultiSync EA244UHD 24" 4K Widescreen Professional LED Monitor - Black @ £899.99 inc VAT
NEC is ushering in a new era of visual experience with the MultiSync® EA244UHD.
The EA244UHD is a high performance IPS display with the latest 4K UHD (3840x2160) super resolution and accurate wide colour gamut capability. Offering the very latest DisplayPort connectivity (UHD at 60 Hz), as well as a range of DVI and HDMI inputs, this monitor can be used in many mission critical applications, where decision making is based on highly detailed, accurate and reliable image quality. Outstanding ergonomic comfort makes it very user-friendly and further enhances professional productivity.
Features:
- Rich detail and complete image overview - 4K UHD resolution 3840x2160.
- Uncompromising image quality and more realistic colour reproduction - 10-bit IPS AdobeRGB Wide Gamut Colour.
- Multi-source management - Advanced Picture-by-Picture to show simultaneously up to 4 different images from a variety of video inputs.
- Ergonomic Office - full height adjustability (130 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
- Minimize power consumption - Human Sensor detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
- Comprehensive network-wide asset management and easier remote support - NaViSet Compatible.
- Expanded connectivity - 6 signal inputs (DVI-D, DP, HDMI, USB) and MHL connection for latest smartphone office productivity.
- Straightforward radiological review applications - DICOM Simulation.
Specification:-
- Response Time: 5ms (gray to gray)
- 1.07 Billion colors (10 Bit)
- Connectivity: 1x HDMI connector, 1x HDMI with MHL, 2x DisplayPort (version 1.2a), 2x DVI-D, 4x USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream
- Full height adjust stand with pivot, tilt and swivel
- Bezel Width [mm] 14.8 (left and right); 18.1 (top and bottom)
- Dimensions (W x H x D) [mm] 558.2 x 386.7 x 218
- VESA Mounting [mm] 100 x 100
- Warranty: 3yr
ORDER NOW
NEC MultiSync EA244UHD 24" 4K Widescreen Professional LED Monitor - White @ £899.99 inc VAT
Features:
Specification:-
- Warranty: 3yr
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black @ £359.99 inc VAT
nonl2br
<p align="left">
OcUK will be the first in the UK to get official UK version of this monitor by upto nearly a month. We are expecting our delivery the last week of May. None of our competitors will get stock until mid-end of June as we have an exclusive arrangement with Samsung. This monitor is one of the best 4k displays available and OcUK will have it before any competitor by upto at least two weeks. Pre-order with confidence from ourselves on this stunning Samsung U28D590 28" 4k 60Hz 1ms Gaming Widescreen LED Monitor.
</p>
<p align="left">
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
</p>
<p align="left">
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
</p>
<p align="center">
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/X5YXWqhL9ik?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/X5YXWqhL9ik?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</p>
<br /><br />
<p align="left">
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)<br />
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)<br />
- Packaging (W x H x D ): 794x452x109 (mm)<br />
- Display Screen Size: 28" (70.8cm)<br />
- Aspect ratio: 16:9<br />
- Panel Type: TN<br />
- Brightness: 300cd/m2<br />
- Contrast Ratio: 1000:1 (Typ)<br />
- Dynamic Contrast Ratio: 10,000,000<br />
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br />
- Response Time: 1ms (GTG)<br />
- Color Support : 1B<br />
- Viewing Angle (H / V ): 170 ° / 160 °<br />
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)<br />
- USB Hub: NO<br />
- Speakers: NO<br />
- Warranty: 2yr
</p>
Only £359.99 inc VAT.
ORDER NOW
Samsung U32D97KQSR 32" 4K Widescreen LED Monitor - Black @ £1,699.99 inc VAT
Unparalleled color accuracy achieved through meticulous factory calibration!
Samsung's professional UD970 monitor is meticulously and individually calibrated right at the factory with an accuracy of ?E<1, ensuring uniform color across the whole screen, and precise grayscale color gradation that is so much smoother than monitors that only undergo a simple software calibration. And with an embedded calibration chipset developed exclusively by Samsung and a 16-bit look-up table (LUT), you get more accurate colors across the entire screen, taking color precision above and beyond other advanced monitors.
Incredibly uniform color presentation across the entire screen.
Every UD970 is individually calibrated for uniformity correction by splitting the display into 25 sections, and then adjusting the brightness of individual sections uniformly with the calibrator.
This results in center and peripheral areas that maintain an amazing calibration accuracy of ?E<3. Samsung's advanced hardware calibration chipset and precise tuning brings the uniformity up from 75% to 90%, delivering near-perfect uniformity values across the entire screen
Color details and clarity in every shade of gray.
From the purest whites to the deepest blacks, the grayscale of the UD970 has been finely divided into 256 levels. Then, with an accuracy of ?E<1, the UD970 is carefully and precisely calibrated from level to level using Gamma Curve and Gray Scale Correction. This ensures color clarity in even the finest shade of gray, so you get lifelike pictures with just the right amount of light, shade and color to express every detail.
White balance correction produces accurate and stunning images.
Creating true-to-life images also depends on being able to fine-tune the color temperature. Thanks to White Balance Correction and built-in calibration technology with an accuracy of ?E<1, the UD970 knows the exact white balance needed and expertly corrects the temperature. It makes adjustments within a range of 4,000K to 10,000K degrees, finely tuning the color temperature in precisely measured increments of 100K, giving you perfect white balance with the rich colors and vivid clarity your work demands.
Vibrant colors with near-perfect Adobe RGB coverage and true 10-bit input.
Samsung-developed BLU technology supports 99% of the Adobe RGB color space, based on the CIE 1931 standard. With almost full coverage of the RGB spectrum, you get incredibly accurate color with minimized color disparity when printing, meaning the colors you see on the screen will be practically identical to the ones actually printed. And using the 10-bit supported panel, 1.0-bit input signals are transmitted and processed through a 16-bit LUT, enabling an amazing 1.07 billion colors to be represented Gorgeous design and stunningly efficient ergonomics for the perfectly professional choice
oFrom display to design, the UD970 provides the most sophisticated viewing experience available. With a mattblack finish and metallic silver back, it will give your office the distinguished, luxurious, and professional look it deserves.
The UD970 boasts advanced ergonomics designed to maximize your productivity. With Samsung's unique
HAS design, you can conveniently adjust the monitor height by 130mm. It also pivots, swivels, and tilts, and provides full support for Auto OSD Rotation
Experience ultimate details and the widest viewing angles
The UD970 delivers best-in-class picture quality with 4X the resolution of FHD and the widest viewing angles.
With a UHD resolution of 3840*2160, you get 4 times more pixels than Full HD displays, resulting in lifelike
details and the ultimate picture quality. And the extremely high resolution of UHD helps professionals reduce unnecessary zooming and scrolling.
Samsung's Pane-to-Line Switching (PLS) Panel delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle
Certified to meet the highest professional standards.
The UD970 features a Fogra PSD certification that verifies its color printing quality has been industry-certified. The image quality has been substantiated by the TUV picture quality master certification, and also carries the UL listed mark confirming that it was produced by a company that limits product risks that can be reasonably foreseen. It also ships with a calibration factory report, so professionals can see the data and check color accuracy levels
A wide range of connectivity options.
The UD970 comes with a wide range of connectivity options, including 2 DP 1.2 ports, a mini DP to DP gender, 1 HDMI 1.4 port, and a total of 5 USB ports. That wide range of connectivity lets you view 4 different Full HD resolution images from up to 4 different sources on your screen simultaneously, giving your greater flexibility and better productivity.
Two different single-color modes on one screen.
The generous size and ultra-high resolution means you can split the screen and still enjoy crisp, vivid images.
Dual Color Mode: This mode lets you use two of the 8 different preset color modes simultaneously on the same screen so you can compare the same image in different color modes with ease.
Quad Windows PBP & Dual Windows PBP:
With Picture-by-Picture, you can split the screen in half or into 4 FHD windows. Thanks to the stunning UHD resolution you don't lose out on any of the glorious picture quality
Specification:
- Display Screen Size: 31.5"
- Aspect ratio: 16:9>
- Panel Type: PLS
- Response Time: 8ms (GTG)
- Color Support : 1B (10-Bit)
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz), 1x Dual Link DVI
- USB Hub: Yes
- Speakers: NO
- Factory Tunning: Yes
- Built in Calibration Engine: Yes
- LUT(Look-up Table) Bit Depth: 16 bit
- Gray Balance: Yes(Delta E? 1)
- Uniformity Correction: Yes(Min ?LR ? 90%)
- Factory Calibration Report: Yes
- Height adjust stand with pivot and swivel
- Warranty: 2yr
Only £1,699.99 inc VAT.
ORDER NOW
Viewsonic VX2880ML 28" 4k 30Hz 1ms Widescreen LED Monitor @ £359.99 inc VAT
The ViewSonic VX2880ml is a 28” 3840 x 2160 Ultra HD display that provides the highest resolution available in a desktop monitor. Delivering four times the pixels of Full HD displays, the VX2880ml features 4K resolution, 1.07 billion colours, and a 50M:1 Mega Dynamic Contrast Ratio for the ultimate in image colour, clarity, and detail. Versatile connectivity options include HDMI (MHL) for connection to smartphones and tablets, as well as dual DisplayPort inputs and one DisplayPort output for daisy-chain functionality. Dual integrated speakers provide enhanced audio for great multimedia and entertainment performance, while a VESA-mountable design offers additional convenience for use as a wall-mounted display. ViewSonic’s proprietary Flicker-Free technology and blue light filter helps to eliminate eye strain from extended viewing periods. The ViewSonic VX2880ml is the perfect 4K multimedia display for power and professional users, including CAD/CAM drawing, content design, and development applications.
This 4K2K Ultra HD display provides the highest resolution available in a desktop monitor. Featuring a 3840 x 2160 pixel screen that contains more than 8 million pixels, this ViewSonic display has four times more pixels than Full HD resolution displays. In addition, the large 28” display can simultaneously display two inputs on the screen, maximizing productivity while delivering the ultimate in image detail and clarity.
With innovative 10-bit colour processing, this display can generate up to 1.07 billion colours for smooth colour-to-colour transitions, as well as enhanced grayscale performance. By displaying up to 1.07 billion colours, the VX2880ml delivers professional-grade colour accuracy and stunning images ideal for any multimedia application.
Equipped with 2 DisplayPort inputs and 1 DisplayPort output, the VX2880ml supports daisy-chaining of multiple displays for multi-screen setup and easy cable management. Even with multiple displays daisy-chained to the VX2880ml, high-definition content and colour remains consistent across screens. Quad HD is supported on two daisy-chained displays (two screens total), while Full HD is supported on four daisy-chained displays (four screens total).
Integrated with Mobile High-Definition Link (MHL), the VX2880ml enables users to connect compatible mobile devices, such as smartphones and tablets, directly to the VX2880ml. This allows digital content from mobile devices to be viewed in stunning Full HD resolution on the larger screen of the VX2880ml, while also simultaneously charging the batteries of the mobile device.
LED backlighting enhances display performance, delivers an outstanding colour range, and adjusts contrast ratios for remarkably detailed images. ViewSonic's eco-friendly, mercury-free LED backlighting further conserves up to 25%* more energy when compared to conventional displays. In addition, LED backlighting provides for a slim, lightweight profile that saves desktop space.
ViewSonic’s proprietary Eco-mode feature is built into all LED displays, offering options to select "Optimize(75%)" or "Conserve (50%)" settings that save up to 25% power. Especially in low ambient light, Eco-mode adjusts brightness and improves visibility, while reducing eye fatigue and prolonging the display's lamp life. With Eco-mode, both lamp replacement and energy expenditures are reduced.
The ViewSonic VX2880ml has two integrated 2W stereo speakers for enhanced multimedia performance with crystal-clear stereo sound.
ViewSonic flicker-free displays deliver on the promise of more comfortable viewing. Instead of using Pulse Width Modulation that continuously turns the LED backlight on and off, ViewSonic flicker-free displays use DC modulation backlights that maintain a steady stream of direct current power—nearly eliminating screen flickering at all brightness levels by providing a constant LED light source. This lets you work at your computer, play games, or watch movies longer – without eye fatigue.
Prolonged exposure to certain levels of blue light can cause eye discomfort. ViewSonic displays feature a Blue Light Filter setting that allows users to adjust the amount of blue light emitted from the screen, enabling longer viewing times and increased eye comfort for work and multimedia applications.
The ViewSonic VX2880ml features a 100 x 100mm VESA-mountable design that allows the display to mount on a monitor stand on a wall, depending on specific needs.
Enjoy excellent performance and accurate colour rendering for everything you view on this display. With 5 different scenario presets, ViewSonic displays offer best-in-class calibration techniques to bring you the best digital viewing experience. This includes Game, Movie, Web, Text, and Mono presets to enhance black levels in games and movies, colour lustre for online images, and colour temperature for reading text.
Specification:
- Size with stand (W x H x D ) : 659.96x510.58x240 (mm)
- Without stand (W x H x D ): 659.96x412.46x52 (mm)
- Packaging (W x H x D ): 732x462x162 (mm)
- Panel Type: TN
- Dynamic Contrast Ratio: 50,000,000
- Resolution: 3840x2160 (30Hz)
- Connectivity: 1x MHL 2.0 (HDMI) (30Hz), 1x DisplayPort (30Hz), 1x Mini-DisplayPort
- USB Hub: NO
- Speakers: Yes
- VESA: Yes (100x100))
- Warranty: 2yr
ORDER NOW
I think it is fair to say we do indeed have the best/largest range of 4k monitors available and in stock along with extremely competitive pricing too. :)
Isn't the 24" Dell IPS and sub £500? Would love to see the pixel density on that, images must look incredible.
I never said it would be good for gaming on, just that it's IPS and sub £500 :p
Suspect it would be decent for slower moving games, you'd need next to no AA at that res and screen size either :)
Specification:-
- Panel Type: TN
- PIP/PBP Support
- Speakers: Yes
- Warranty: 3yr
ORDER NOW
I got this 12 days ago from OCUK and I'm in love with it :D
