Tuniq Tower + P35-DS3R - fan not spinning?
2 Apr 2007
I just 'completed' a new build and installing the Tuniq tower onto the GA-p35-DS3R motherboard. I plugged the brown connector from the tuniq into the CPU_FAN header on the motherboard, and that white connector to the fan control that came with it, but I can't hear the tuniq tower at all, I don't even think the fan is spinning...is it botched or should I plug it into the SYS_FAN.
Oh, and the CPU_FAN header was a four pin thing, but the Tuniq's brown thing was only three?
Any help would be appreciated...don't want to destroy my new CPU (although, SpeedFan is telling me it's idling at 32 degrees)
Have you got the fan setting in the BIOS enabled. I have same board and HS but I plugged my fan into the molex
