- 20 Oct 2020
Hello there!
I would like to ask for your help! I am planning to buy a new monitor, but I am totally confused. At the moment my PC is connected to an older LG 43' UHD TV (without HDR, VRR or any useful feature). Firstly I wanted to buy an ultra wide monitor, with 144hz, 1440p, G-sync (or at least G-sync compatible FreeSync), 1-5ms, IPS panel, and at least with 34 inch. Then I checked the prices...hmmm, go back to the televisions! Okay, I lowered my expectations: 144hz and 1-5 ms is useless, I am not a professional player, I don't play with competitive games. G-Sync and Freesync...ok let them go, V-Sync rulez. But I don't want to buy a tv below 4k resolution, IPS panel, which has a native 120hz on 1080p and has an acceptable response time (10-14ms on game mode). But man... I didn't find a native 120hz tv below 55 inch. I love huge screens, but 140-150 cm is totally overkill, and the screen will collapse on full hd resolution. Really can't belive it. So, I am where I started. Best solution of course is a 43' LG B9 Oled, but unfortunately I am not a native of Bill Gates.
So could you please advise some TV/monitor with the following parameters? : at least 120hz on 1080p, IPS panel, at least 34 inch but maximum 49 (it can be curved, flat, 16:9, 21:9, really doesn't matter). If it's a TV, then a game function for quicker response time is an advantage. Maximal amount is 700$.
Thank you very much in advance!
