Two 3pin fans on one 3pin cable?
17 Sep 2007
West Yorkshire / Market Bosworth
Having a look at this:
http://www.overclockers.co.uk/showproduct.php?prodid=CM-003-LL&groupid=701&catid=209&subcat=
But the thing is, ive got one more dial on my fan controller that i can use. So was thinking if anything was about that would mean i could take the two 3pin fan cables and plug into an, (not sure of the name) but i guess an adapter so that i could change the rpm of fans together on one dial, so they are equal, say 1000rpm 1000rpm but only using one dial.
This:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-013-AK&groupid=701&catid=48&subcat=
Looks like it will do the business but these sort of things always confuse me whether or not they will be compatable with my Scythe Kaze-Master fan controller.
Cheers in advance.
I use the same adaptors to power 5 sharkoon silent eagle 2000 fans, my fan controller is an akasa junior that has three channels, i run 2 fans on 2 channels via adaptors and a single fan on the remaining channel. Find out what sort of current the fans require and what your controler is capable of supplying per channel.
Thanks for the quick reply, those are the fans i were planning on using :D, sharkoon silent eagle 2000rpm 120mm fans, got them in the rest of my case you see. ;)
Now im thinking then to join up my two intake fans (sharkoons) and then have my exhaust on one, then cpu cooler (if thats possible?) then maybe the lian li fan pci that i linked above.
Going to get that cable next anyway even if i dont get the lian li thing. :cool:
The performance itself, moved no air what so ever, made my gfx card hotter :o
Performance would depend entirely on the whether the fans were intaking or exhausting air and whether the gpu was just a single slot cooler or a dual slot. Example, my 8800gts (dual slot) exhaust air out the back, rather than something like my old 7800gt (single) which just blew air around. :rolleyes:
