** TWO INCREDIBLE PRE-ORDER DEALS FOR CHRISTMAS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Got a couple of incredible deals for you and the AMD card comes with AMD Gold award and Civilization game code. :)
MSI Radeon R9 290X Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5000Mhz (Samsung IC)
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Samsung S34E790C 34" WideScreen Super-Wide Curved LED Monitor @ £799.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
VA’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved VA provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 100% colourspace and VA’s accurate colour expression.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: VA
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 100%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 3000:1
- Response Time: 4ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 16.7M (8-Bit)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3000R
- Connectivity: 2x HDMI 1.4 (50Hz), 1x DisplayPort 1.2 (60Hz)
- USB 3.0 Hub: Yes x4 (1up 4down)
- Speakers: 2x 7W
- Tilt: -5 / +20
- VESA: 100x100
- Warranty: 2yr
Was [£989.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Both products and deals are exclusive to OcUK and are only whilst they remain on pre-order status, stock is due on both items mid-end next week. A cracking Christmas deal!! :)
Thats an amazing deal on the lightning, still even get the free games, to take it to about £200 if you sell them
Amazing price on the 290x Lightning. Do you know what the noise is like when the card is idle? I've read mixed reviews from silent to really loud!
If you want a silent MSI card get the GTX 970. Mine is totally quiet during "normal" usage as the fans don't spin at all until you start hitting the card for some gaming performance.
Yep, that's what's making me consider between the two cards, or potentially a quieter 290X. Doesn't have to be silent, just not as loud as some reviews have suggested :cool:
I found it quiet, if its loud, control the fans manually or set up a fan curve. :)
This is a really good deal on the 290X but good deals this good tell me one thing -
"about to be replaced by new generation of graphics cards from AMD"
So clearing inventory.
Holy moly, that Samsung screen is so sexy. I just wish more games would support 21:9 natively since it's becoming pretty popular.
Just taken the plunge on a Samsung, so really hoping that an ETA of 19/12/14 means it might just be delivered in time for Santa to briefly bob it in his sack! :)
