***TWO VERY SPECIAL MONITORS: HAZRO HZ27 Series!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK I know you guys have been awaiting these for months and they are now finally near here. These new panels from Hazro feature the same panel as the amazing Apple Cinema Displays but Hazro are using LED backlighting for more vivid colours and at the same time are offering them for considerably less money. So Apple display quality but several hundred pounds cheaper. These are exclusive and only available through Overclockers UK and stock arrives within the next couple of days:-
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £419.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D [HDCP Supported]
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
Was [£499.00] Inc. VAT
Only £419.99 inc VAT.
ORDER NOW
Hazro HZ27WA 10-Bit 27" LED Widescreen Professional Monitor - Black @ £519.98 inc VAT
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
Features:-
- 1 x HDMI
- 2 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- 10bits [.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
- 3yr RTB Warranty
Was [£599.00] Inc. VAT
Only £519.98 inc VAT.
ORDER NOW
Response time is horrid for a gaming monitor!
No its not, my DELL 30" was 8ms and I gamed on that in fast action games such as Quake 3 and the 8ms was never an issue. So I can't see how a 6ms would be an issue. :)
6ms does not mean good gaming. This is only one side to it.
An old dell with a 16MS response but ZERO input lag will be faster than your cheap 2ms screens of today.
This is essentially the same panel as you find in the U2711.
The hazro has a fantastic low input lag. Couple this with a 6ms response and it will be fantastic for gaming.
This is no different when those with little knowledge assume that more mhz = faster or that 6 cores at 3ghz means 18ghz right?
No/low input lag is much better than response time so to say a monitor is bad for gaming due to a 6ms response is one hell of a wild statement that just cannot ever be backed up.
if you play cod, get 3 of your friends together, and ill get 3 of mine 2 will 30" dells one with a 30" hazro lets see who's response time matters
If there anything like the old hazro screens, they will be brilliant for the money
glad i got my dell for 519.99 few months back otherwise it would have been one of these. awesome price and the screen is amazing!
This is incorrect. Whilst we can't publicly announce panel part numbers, these displays feature LED panels whereas the model quoted above utilises a CCFL panel.
Indeed, however that is a lighting feature hence the difference, pitch, response etc etc is the same.
