[TW]Taggart;22879409 said:for referance, a clay bar is what you should have used to get tar off.
I found the claybar only gets off the loose ones. Buy some Tardis for a few quid off ebay as that stuff works well and get a 3 pack of microfibre clothes from a supermarket/homebargains for a quid.
The guy from work give me some Turtlewax Safe cut Scratch remover and it worked a treat with a little elbow grease
I'm fully aware how polishes work thanks. Polishes are a light abrasive, where as T-Cut is basically paint stripper.
