Hi there
OcUK has secured stock on DELL's first Super-Wide LED Monitor and it looks stunning:-
Dell UltraSharp U2913WM 29" Super-Widescreen LED Monitor - Midnight Grey @ £599.99 inc VAT
Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with a 21:9 aspect ratio and 2560 x 1080 Wide Full-HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178°/178° (typical) ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
Experience remarkably precise and accurate color made possible by over 99 percent sRGB at a delta-E of less than 5, offering broad color variation. Plus, the U2913WM comes factory color-calibrated, so you can enjoy outstanding color accuracy right out of the box.
Make it work for you, with extensive connectivity such as DisplayPort 1.2, USB 3.02, Mini DisplayPort, DVI and HDMI, plus highly adjustable tilt and swivel positioning, a 130mm height adjustability range and a VESA-compatible wall mounting option (mounting kit sold separately).
Synchronize your applications and improve your visual experience. Dell Display Manager offers a variety of features that can optimize your media presentation and maximize your monitor’s real estate, such as Easy Arrange and Auto Mode.
Automatically optimize your video settings with the Smart Video Enhance3 feature, optimizing colors and sharpness for the best possible presentation. Choose Movie mode for recommended settings, or choose Advanced mode to manually adjust contrast, sharpness, color saturation and hue however you like.
Stay energy-efficient with PowerNap and dynamic dimming features that automatically help regulate power usage. Plus, the U2913WM features an eco-conscious design with arsenic-free glass, mercury-free LED and BFR/PVC-free laminates in the chassis. The U2913WM is EPEAT® Gold and ENERGY STAR® qualified and comes packed in eco-conscious recyclable packaging.
Specification:-
- Panel: 29-inch (73.02cm) (diagonal) VIS with LED backlights
- 21:9 aspect ratio
- LED Technology
- Contrast Ratio: 2,000,000:1
- Brightness: 300cd/m
- Response: 8ms
- Resolution: Wide Full-HD 2560 x 1080 at 60 Hz (Max)
- Viewing Angles: 178°/178° ultra-wide viewing angle
- In-plane switching technology
- Color calibration factory report
- More than 99% sRGB (deltaE < 5)
- Input Connections: DisplayPort 1.2 / mini-DisplayPort, DP-out, HDMI, DVI-D (HDCP), VGA
- USB3.0 Hub (4 downstream / 1 upstream)
- Tilt, swivel and height adjustable (130mm)
- Option to wall mount in landscape and portrait mode (VESA 100mm x 100mm)
- Arsenic-free glass and mercury-free LED panel
- Dell Display Manager - Auto mode, PowerNap, Easy Arrange, Smart Video Enhance
- ENERGY STAR®, EPEAT Gold, TCO Certified Displays, ErP Standards compliant
- 3yr Onsite-Warranty
Only £599.99 inc VAT.
ORDER NOW
Specification:-
- 21:9 aspect ratio
- LED Technology
- Response: 8ms
ORDER NOW
