- 11 Dec 2005
- Cheshire
"Ultima Eclipse" Intel Core i7 930 2.80GHz @ 4.00GHz DDR3 System @ £1,549.98 inc VAT
The "Ultima Eclipse" is our flagship system based on the Intel Core i7 platform and Intel X58 Express chipset. Your options are open with the versitility to be air or liquid cooled depending on your preference. Featuring the Asus Rampage Extreme III you have control of the most advanced X58 motherboard available, with USB 3.0 and SATA 6Gb/s compatibility the Rampage Extreme III covers all bases. With ATI Radeon HD 5870 and HD 5970 graphics cards to choice from you have the ability to maximise your gaming potential. Experience masterful overclocking power with a 4.00GHz overclock cooled by either the Premium Prolimatech Megahalem Heatsink or custom liquid cooled installed and configured by our expert team.
Why Should You Buy This System?
- The 4.00GHz overclock ensures lightning fast processing speeds
- Sleek and stylish Cosmos RC-1000 Pure Black Edition
- Custom Watercooling option for ultimate performance and silence
- Featuring DX11 cinematic graphics
System Specification
- Case: Coolermaster Cosmos RC-1000 Pure Black Edition
- Cooling: Prolimatech Megahalem CPU cooler (air cooled option)
- Power Supply: Corsair TX 650W
- CPU: Intel Core i7 930 2.80GHz Overclocked to 4.00GHz
- Motherboard: Asus Rampage Extreme III (Socket 1366) PCI-Express DDR3 Motherboard
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: XFX ATI Radeon HD 5870 1024MB GDDR5 or XFX ATI Radeon HD 5970 2048MB GDDR5
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Watercooling Specification Option
- Radiator: Black Ice Stealth GT 240mm Radiator
- Pump/Reservoir: XSPC Dual Bay Reservoir/pump (750lph)
- CPU Block: EK Supreme HF Nickel Universal CPU block
- Fittings: x6 1/2" Stubby Barbs Black Sparkle
- Tubing: x2 Masterkleer 7/16" Tubing - 1m (Total 2 metres)
- Fans: x2 Sharkoon Silent Eagle 2000RPM 120mm Fans
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Leading the way in style. The "Ultima Eclipse" glides through applications and games with ease and silence. Extreme power calls for extreme cooling, get yours now.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Only £1,549.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
