I've noticed this in music in particular; the volume goes up and down of it's own accord (not visibly in software). This happened a few years ago with the same speakers (different machine and sound card) and now it's happening again. It's not by a major amount, but very noticable. It's almost like, when there's a much louder part of a song starting, the volume is reduced, then it recovers again very quickly.
I have Creative Inspire 5.1 (analogue) about 5 years old now.
The first time I took apart the volume and bass control 'pod' and blew a little dust out, upon putting it back together it seemed to work fine, and for a long time until now. Before that I used to tap the pod thing on the desk and it'd eventually stop. So i'm wondering if this is the problem again, and if there's a known fix/replacement part or i'll have to get a new set of speakers, because it's annoying! It doesn't happen all that often though. Is it possible to run the speakers without the pod? It controls volume and bass, but also acts as a switch to turn them on....
I haven't noticed it in games, only music, but it may well happen without me realising tbh, i'm usually too busy getting fragged to notice
Any suggestions? Spec is in sig if it matters.
EDIT: The bass unit says they're Inspire P580 and the creative site has a P5800 which look identical to mine.
