I’ve done a search and found that the Logitech Harmony remotes are the ones to get but it’s for my parents who are retired now and need any remote to be very, very easy to use.
They recently got a freesat box installed but end up watching terrestrial most of the time because they can’t figure out the combo of remotes for the TV, Freesat box and DVD player.
How easy are the remotes to use and setup, I essentially want to do the following, is it possible?
Thats it, I want it super simple for them. My other concern is that when replacing the batteries on the Harmoy 300 does it loose all the settings?
- Turn on TV and Freesat box with one button press, pressing ch+ and ch- moves between freeview channels
- Turn on TV and DVD player with one button press, pressing play on remote plays the DVD
- Using volume up / down works for the TV only as they usually end up muting the freesat box and have the TV volume at max!
