1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Upgrade My GTX260 but not changing system
Discussion in 'Graphics Cards' started by justyjust, 3 Aug 2014.
  1. justyjust
    Hi people
    Been a while since I upgraded my pc, still running old gear but its still going well for what i need it for. I have changed the location of my pc and brought a smaller case as my cooler master comos it one huge mother.
    My specs
    intel Q6600 2.4GHZ quad
    8GB DDR2
    Asus P5Q Deluxe
    2T HDD
    GTX260 without HDMI
    In the near future Im going to build a new high spec ITX but for now i want to upgrade my graphics card to enable me to have a HDMI, i been looking at upgrading to a GTX295 but also been looking at newer cards but as I'm not upgrading my hardware maybe its not worth it.
    the only games i play on the pc is rocksmith and ruse maybe some other new games, I'm not to fussed about dx11 but would be nice if my systems any good for that.
    what do you think, looking to spend up to £60 secondhand if needed GTX295 or not
  2. Minstadave
    Caporegime
    GTX 295 is an odd choice, will be power hungry for its performance. You'd be better off with something like a 7950/760.
  3. Gregster
    Caporegime
  4. joeyjojo
    Have a look at this handy GPU hierarchy chart
    http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
    £60 SH will get you up into the 7850 category (I got one for £50 posted last month, so maybe even the one above) which also contains the 295. But, you'd be mad to get a 295 over a 7850. It's old technology and very energy inefficient relative to new stuff.
  5. andybird123
    Capodecina
    2nd hand 650ti would get my vote
  6. justyjust
    I have been looking out for a gtx560 seems a pretty good card all round
  7. joeyjojo
    The 5 series are a decent option, but relatively power hungry by todays standards (released in 2011 so can't blame them). In the last 12 months I went (prices include P&P):
    GTX 260 (£27.50)
    GTX 460 (£40)
    GTX 560 Ti (£51)
    HD 7850 (£50)
    Every step was an upgrade. I'd recommend going for the newest card you can, something like an AMD 7790, 7850, or R7 265.
    On the Nvidia side you really want a 650 Ti Boost. The 6 series (Kepler) were a huge improvement over the 5. However they've held their value a lot better than competing AMD cards so you probably won't find much in-budget. The plain 650 Ti isn't all that much faster than your 260, you can do a lot better.
  8. almighty15
    PermaBanned
    Why not get a GTX750ti
  9. varkanoid
    Capodecina
    +1
  10. joeyjojo
    The 750 Ti is £100 new, OP is looking for £60 SH.
    P.S. the R7 265 is a better choice than the 750 Ti for exactly the same price (more future proof).
  11. Resa69
    Gangster
    +1
  12. Doogles
    Mobster
    HD 7850 2GB would be great, I had two of them in crossfire and loved them, at 1080p they are great and would balance your system brilliantly. Overclocks like a god also :)
  13. gurusan
    Capodecina
    I'm still running my 7850 and am very pleased with the performance.
    I would advise overclocking the Q6600 to at least 3.4GHz
  14. apostolis_kt
    Wise Guy
    7850 is the way to go on that price range.
    Q6600 great processor brings back memories when i wanted one so bad but in Greece was stupidly expensive.
