It does have a backplate but it's about 2CM wider then my current power supply, I cant remember the name of the case it's the one they used just before the current one, predator 2 comes into mind for some reason????
With Windows 7 I'm gong to have to buy that as I have Vista at the moment, why would I buy the Retail windows 7 over the OEM?
May I ask what the make and model of your current PSU it?
If it is a Predator 2.0, then this takes standard ATX power supplier - so wouldn't be an issue with a PSU like the very nice Antec Truepower 650W mentioned above.
With windows 7 OEM means that when you install it on one PC - the license is tied to the motherboard of the system you install it on. If you want to change computers (or just the motherboard) then legally you need to buy a new windows license. With a retail licence, you can still only have it installed on one PC at a time, but when you change computers or motherboards you can legally install windows on the new system.
To set to AHCI I do that inthe BIOS correct?
Exactly.
