Urgent help needed regarding ATX power supplies!
Permabanned
19 Dec 2005
I started installing my new Motherboard today, and it has a 24 plug ATX power connector. Touble is my PSU has an ATX connector with only 20 pins.
I thought ATX was a standard thing so all PSUs worked with all mobos?
The plug will still connect to the connector on one side, is this what I'm meant to do or do I need to get an adapter or even a new PSU?
Thanks for any help.
Most mobo's work with just the 20pins in as you describe you have fitted it.
You can buy a 20->24pin converter cable for a few pounds.
Apparently Mobo's tend to run more stably with the 24pin connector in situe.
[EDIT] Make sure that your PSU has a decent rating. No point in connecting a poor old PSU to your nice new board. If you have anything less than a 400w of a reputable make, i'd get a new PSU.
[/EDIT]
M
