1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Usb 3.1 help
Discussion in 'New to PC gaming & upgrade advice' started by Scottthomas, Nov 4, 2019.
Tags:
  1. Scottthomas
    Hi, I have put my old pc into a new case. The new case has a usb 3.1 on front panel but my mobo only has 2.0 and 3.0. Is there an adapter I can use to make use of it (I don't mind it running at 2.0 speed). Thanks.
    Asus M5A97 EVO R2.0
  2. CuriousTomCat
    Wise Guy
    Just plug the USB 3.1 from the case to the USB 3.0 on the motherboard
  3. Scottthomas
    Thanks for your response, it's a different connection I would add an image of I knew how from mobile?
  4. CuriousTomCat
    Wise Guy
    I think I know what you mean. You need an InLine USB 3.1 to 3.0 adaptor. You can google the product code 4043718277414.
  5. b00merang69
    Perma Banned
  6. EsaT
    Sgarrista
    USB3.1 is same as USB3.
    So is also USB3.2, because of marketing scammers keeping renaming it.
    Only USB-C different.
    For that you need something like this:
    https://www.silverstonetek.com/product.php?pid=871&area=en
    But remember that means having only one USB port in case instead of two:
    USB3 header has wiring for two USB-A ports
  7. an0nym0us
    Wise Guy
  8. Scottthomas
    Thank you all for your help, much appreciated.
    EsaT that's the one and an0nym0us the top picture thank you. Any ideas on its name? Or a link to a UK shop. Thanks everyone.
  9. Scottthomas
    No worries I found it, thanks guys.
