12 Feb 2006 at 16:28 #1 Maniac618 Maniac618 Associate Joined 21 Jan 2006 Posts 1,009 Possible? Tried connecting the 360 to the laptop via the vga input at the back of the laptop, but can't seem to change it from windows to the 360? Any ideas?
12 Feb 2006 at 16:30 #2 cokecan cokecan Soldato Joined 4 Jan 2004 Posts 7,840 Location Nottingham are you sure the vga input is actually an input??? ususally their outputs, cant really see why a laptop would need a vga input on it
12 Feb 2006 at 16:30 #3 Wrathamon Wrathamon Associate Joined 18 Oct 2002 Posts 1,542 Location Edinburgh Are you sure it's a VGA input on your laptop? Most laptops have a VGA port - but output only - to connect them to a standard monitor.
12 Feb 2006 at 16:33 #4 Maniac618 Maniac618 Associate OP Joined 21 Jan 2006 Posts 1,009 it could quite possibly be vga out, how can i check?
12 Feb 2006 at 16:37 #5 da_mic_1530 da_mic_1530 Soldato Joined 31 Oct 2005 Posts 8,868 Location Leeds it will be, all my laptops only have output, none have s video in etc etc
12 Feb 2006 at 16:37 #6 Maniac618 Maniac618 Associate OP Joined 21 Jan 2006 Posts 1,009 ok, well my mate will have to play with his normal tv then. thanks guys.
12 Feb 2006 at 16:38 #7 DaveyD DaveyD Man of Honour Joined 19 Jan 2003 Posts 12,645 Location Warwickshire Maniac618 said: it could quite possibly be vga out, how can i check? Click to expand... If it's the only VGA port on your laptop, then it's almost certainly the VGA output.
