Vista 64-bit Wireless Card Survey
2 Sep 2006
Portland, OR
If you have a wireless card that is working under Vista 64-bit RC-1 then please:
-List Model Number, type (PCI/USB), how much you paid
-Say whether you are pleased with the range/performance, whether finding the correct drivers was easy or not
Thanks so much
17 Mar 2006
So far I have completely failed to get Vista to see my KCorp KLG-530 pci card...so no wireless here yet. The drivers seem to have installed but it doesn't see the hardware :(
Running Vista RC1 5600 64bit
2 Sep 2006
Portland, OR
Ok well I took a chance and bought a Belkin PCI Wireless G card based on the Broadcom wireless G chipset and Vista 64 bit detected it and install the drivers automatically!
Works wonderfully!
18 Feb 2003
York
I managed to get my linksys wireless G v2 work with some driver editing, planetamd64.com had the original driver and a walkthrough on how to get it to work.
19 Feb 2004
Darlington, UK
Mine works fine, using the onboard wireless of the Asus P5W DH Deluxe. I had to download the Realtek driver for it but it works a treat.
Top
