w810i battery life?
31 Aug 2003
not sure if this is just me but the battery seems to only be lasting a day with normal use. is my battery gone or is everyone having these problems?
yes i have charged it overnight but it only seems to last a day, any tips on extending the life or should i just get a new battery?
wierd, mine goes down relatively fast but im getting a good few days out of it using the walkman, phoning and texting a fair bit you might have a duff battery, try running it down completely and then having a good charge overnight whilst it is turned off.
I know that a few people came back with the w900 because they had a real short battery life, maybe the same situation, take it back to the shop and tell em, they should give you a new battery
