Wall lamp to plug lamp
2 Feb 2021
Hello,
I bought a lamp and didn't realised it was just a wall fitting lamp and didn't have the option of plugging into the plug.
I would like to see if someone can help me if is possible to just convert it to have just a cable to plug it and use the switch that It has turn it on and off.
I tried to attach you a picture
gvnzc7Z
13 Sep 2003
Glocestershire
You could, ideally i'd mount it on a piece of wood. With the bottom open like that while it's not dangerous it's not really safe enough if that makes sense.
EDIT: You need to use 0.5 or bigger flex, if there's an earth connection (and since it's metal there should be) it needs to be 3 core. And you need to fit the plug with a 3 amp fuse.
19 Jul 2011
You could build a small movable wall and fit it to that with a flex and plug at the bottom.
Why you wouldn't take the lamp back and buy a table lamp, I don't know.
OP
2 Feb 2021
Thank you both for your help.
Well I don't want to take it back because I want this type of style in the room, that's why the question ;)
