Washing machine frozen up, burst inside, electricals gone
i've always wondered what would happen if you filled a washing machine with diet coke, and grinded up a load of mento's to use as washing powder....
Open the coin trap door if there is one. There will either be a small latch you can pull that will release the door, or a tube with a tap that you can drain the machine with.
Then you need a crowbar and a friend to video you :cool:
Isnt Hotpoints Standard Warranty 5 year parts 1 year labour? If so might be cheaper to get it fixed instead of buy a new one...
Bosch are the only decent brand left
a control board alone (most common thing to go) on hotpoint/indesit costs over £100
I recall from when mine went .....I just bought a new Bosch instead.
advise was given to buy Bosch from white goods forums and the local repair man.
Miele are good yes, but you can't get one for £200.
But you can get a second hand (reconditioned one) for half that. I got mine for £90 and it's been perfect so far. Actually washes really well too :) If it lasts even just 2 years (I'm expecting 4-5) then it works out a fraction of the price of a normal machine.
