Hi,
The heat generated by my pc is relatively high, and I fancy overclocking in due course, therefore temperature are likely to get even higher. Also I seem to have accumulated over 9 fans in my pc which all make considerable amounts of noise which annoys me! Therefore I believe that a water cooling solution would come in handy.
Therefore I am wondering what I would need to buy and how much it would all cost; here's my spec that all needs water cooling.
Coolermaster RC-1000
Striker II Extreme
QX9650
2 x 8800 GTX OC2
(I would prefer an all inside system, whereby the radiator is in the pc rather than an external one.) I have 3 free 5.25" drive bays.
thanks,
Striker II Extreme
QX9650
2 x 8800 GTX OC2
thanks,
) then be prepared to start cutting away at your case with a jigsaw or dremel.
