Hello all. Apologies for the long boring thread in advance.
First, some specs:
mobo - Asus Rampage II Extreme
cpu - intel i7 920 @ 4.2ghz
cooler - Noctua (forgot the model, sorry
ram - corsair 6x2gb DDR3 1600 @ 1600
vga - 2xPower Color HD5870 in CrossfireX
case - Antec 1200
The system is entirely air cooled (have never water cooled before). The above overclock is achieved by setting BCLK at 200mhz, and multiplying by 21 for CPU and 8 for RAM.
CPU idles at 30-40, active at around 50 (the Noctua is a great cooler!), northbridge is at 50-60 though (is that too much? It's right next to the VGA though)
My main gripe with the system is the noise (and heat!) the VGAs generate. when idle, they're at around 50 degrees with 5-6000rpm fans. BUT, the moment a game is on, one of the cards runs between 85-90, with a fan that can reach 11000! (and obviously is loud).
Everything is stable though, stress tests galore are fine, and prolonged 3D gaming sessions are all ok.
Nevertheless, I think that watercooling (especially the VGAs) is now the order of the day. I've never watercooled before, and hence will be going for a noob-friendly external solution. Here's what I had in mind:
1\ Zalman Reserator XT
2\ 2xEK HD5870 VGA blocks
3\ Zalman NorthBridge block
As the system is compatible with 1366 sockets out of the box, I thought I might as well remove the Noctua and water cool the CPU while I'm at it. So, in essence, I should end up with a water cooled CPU, NB, and both VGAs.
Having never watercooled before, I'd rather opt for this external solution, and if I like the idea then future builds can have an internal, better solution. But, for now, this is what I'd like to do.
And, on to the 2 questions (finally!)
1\ Does anyone know if the VGA blocks are crossfirex compatible? I can't find anywhere if they are or not, and physically to me they don't look like they're gonna block the crossfirex connection slots.
2\ Will I need any other fittings/accessories in order to attach the NB block and VGA blocks? If I do need something, can you kindly tell me exactly what it's called, as I have no clue what the lingo means
And thanks!
First, some specs:
case - Antec 1200
And thanks!
