- 10 Aug 2015
Had enough of the fan noise on the stock cooler for my vega 64 asus strix
Going water cooled
Whats the best option please
Going water cooled
Going water cooled
Is it that bad?Had enough of the fan noise on the stock cooler for my vega 64 asus strix
Going water cooled
What I didn't like during my very short ownership of the Vega 56 Pulse was the fact that the fan won't spin until some temperature, then the surrounding area would be always warm/hot. And under load, most of the hot air was blown against the motherboard and the side panel. The M.2 was always around 70 to 80c. The GPU before that, an Asus HD7970 DirectCUII was much better regarding cooling. Most of the air was blown outside the case.Is it that bad?
I have just water cooled my CPU, and my Nitro+ Vega 64 fan rarely spins up
Personal experience, I would go with a Vario pump, which allows the speed to be manually selected, not PWM. Soft tubbing is easier to work with and cheaper too.Ditto. I'm keen to have a go to, I am currently running a Vega 56 (stock AMD) and its overheating like crazy, its doing my nut!
This is quite tempting https://www.ekfluidgaming.com/ek-fluid-gaming-a240r but i really don't know much about it and am hoping others can help advise based on their own experience.
