Watercooled 3080/3090 VRAM temps - Copper Shim installation
6 Feb 2019
Just FYI it's impossible to install an active backplate on the Asus x570 Formula motherboard- we've tried and it will not fit
18 Aug 2014
3090 EVGA with EKWB velocity waterblock and active backplate:
GPU core when mining 46°C
Mem temps 84°C
Pushing +1900 on the memory.
Gaming temps are 52°C on the core and 64°C on the memory
All fans set to 40% regardless giving a near silent operation
20 Dec 2020
Leeds
3080ti Founders Edition
EK Quantum Vector FE
GPU temp 32c idle and 57c after four hours of Battlefield 2042 & PUBG
GPU memory junction 38c idle and 58c after four hours of Battlefield 2042 & PUBG
GPU Hot Spot 39c idle and 63c after four hours of Battlefield 2042 & PUBG
14 Apr 2009
Cheshire
That's a great delta temp. Mine seems to be settling back to 10c.
Is this all at stock?
20 Dec 2020
Leeds
Yes I`m very happy with that and yes all on stock, not had a mess about with afterburner yet.
I did notice that yours was around 12c delta, it`s good that it`s settling down to around 10c now.
31 Dec 2010
Asus ROG Strix 3090 (non-oc variant) + AlphaCool Eiswolf 2 (modified backplate with my own active cooling, see https://forum.alphacool.com/threads/alphacool-eiswolf-2-for-3090-strix-wrong-size-of-padding.2809/ for details on my mod) / https://hardforum.com/threads/asus-...tercooled-temperatures-3dmark-scores.2017452/ for my rig.
GPU is overclocked: +175 Mhz GPU / +250 Mhz Memory / 137% TDP
Idle temperatures:
CPU Tdie: 44.5c
CPU Die avg: 35.7c
Asus Chipset: 58.5c
GPU: 25c
Hot Spot: 32c
Memory Junction (VRAM): 32c
VRM: 29c
Stresstest: 30 minutes Unigine SuperPosition @ High Textures / 3840x1600
Stress / Load (Non-OC) Peak Temperatures:
CPU Tdie: <not measured>
CPU Die avg: <not measured>
Asus Chipset: <not measured>
GPU: 56.1c
Hot Spot: 66.2c
Memory Junction (VRAM): 66c
VRM: 48c
Stress / Load (OC) Peak Temperatures:
CPU Tdie: 70.8c
CPU Die avg: 66.6c
Asus Chipset: 64.8c
GPU: 65.6c
Hot Spot: 76.3c
Memory Junction (VRAM): 72c
VRM: 53c
3DMark scores (OC):
TimeSpy: Overall: 19538 GFX: 21431 CPU: 13023 - https://www.3dmark.com/spy/26080542
TimeSpy Extreme: Overall: 10647 GFX: 11060 CPU: 8789 - https://www.3dmark.com/spy/26078840
Port Royal: GFX: 14949 - https://www.3dmark.com/pr/1430299
OP
18 Oct 2002
Aranyaprathet, Thailand
11 Jun 2021
UK
I have a 3090 FE with a EKWB FE Block and the idle temps are 28c and gaming around 55c (60-70c mem). I do use an undervolt 1900Mhz @ 867mV but since had to just reduce power limit to 73% to keep the energy bills a bit lower :D
6 Feb 2019
Thats high temps for WC and an heavy undervolt
That card would be at the same temp or even lower with its air cooler put back on
18 Jul 2009
Byksi active backplate with Gelid Extreme 1mm pads and thermal putty. Fluid temp between 26-30 degrees.
18 Oct 2009
Gold Coast.
My first time with custom a WC loop.
Both my 9700K @ 4.8 and my RTX 3080 are in the same loop as follows...
2x 40mm EK 360mm rads with 6 x Arctic P12 fans @ 1800rmp, an EK Quantum Magnitude CPU Block and a EK Quantum Kinetic TBE 200 D5. I wouldn't mind having some faster fans maybe...
My GPU now in summer tops out at about 50-52c (room temp 25c?) when gaming and in the winter hits about 46-48c with room temp about 20c?
My CPU gets a bit warmer but idles at 28-30c in the winter and 35c in summer with about 65c in gaming even tho its been delidded....!?
I'll never not WC a GPU again, my PC so bloody quiet :p took me 15ys to try tho...
OP
18 Oct 2002
