Hi guys,
Here are the watercooling parts Ive been advised to buy. Could you guys check for me.
My specs are:
cpu: q6600
mobo: asus maximus formula
Ram: 8gb ddr2 6400
graphic cards: Two 8800gts (cheaper then 1 9800gx2, dont know when the ocuk version of 9800gx2 is coming)
Zalman 1000w psu:
Case: Between, lian li v2000, Silverstone TJ07, Zalman GT1000 Z-Machine , Coolermaster RC-1000 Cosmos.
Im going for quietness over anything, and Im looking to overclock too, Im getting the sound recuding mats for the case and rubber things to help make the psu and hdd's quiter too.
Here are the watercooling parts recommended to me:
• Lian Li V2000B high quality brushed aluminium case
• XSPC R120-D (240mm) Radiator - Mounted on the top panel
• 240mm AC Ryan Radiator Grill of your choice
• Xilence Red Wing 120mm fans x 2
• D-Tek Fuzion CPU Block with Nozzle Pack installed
• XSPC Dual Eye Ball Bay Reservoir
• 10W Laing DDC Pro with Petra’s Tech top
• Custom installed 1/2" Hose with Helix coils fitted!
I cant find most these parts on overclockers.
But let me know what you guys think, Im looking for the quietest solution but also overclocking. Is there other parts I can buy which are better? I want to try to have it all on the inside, but maybe a zalman is better.
He said he can do all that for £450 plus the v2000 case.
and then another £200 to build and overclock my pc. Let me know what you guys think.
Thanks
My specs are:
cpu: q6600
Ram: 8gb ddr2 6400
Zalman 1000w psu:
Thanks
