WD WDCWD5000AKS-00TMAO install problem
Caporegime
24 Dec 2005
Autonomy
Hi,
Just installed this into a brand new PC using an Asrock 1333 DVH mobo.
Setup only sees a 127gig drive :confused:
Install windows anyway and disk management only sees a 127 gig drive.
Can't see any jumpers.
Is the drive faulty?
Never seen this before and I have built hundredsw of pc's :confused:
rafster said:
Its showing up in BIOS as 127gb?
If you mean setup as in XP setup...XP pre SP2 install? Vanilla XP doesn't support >127gb
cheers for that.
Just realised I used an old XP cd at work..Didn't have SP2 on it! :o
