Weekend Case and PSU Bundle Deal
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Great deal for this weekend only...
Cooler Master HAF X with Coolermaster GX 750W PSU @ £149.99 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Bottom mounted PSU
The latest addition from Cooler Master is a range of power supplies that specifically targets the upper mid-range to high-end gaming systems, the Coolermaster GX Series. The Coolermaster GX range of power supplies feature a single powerful +12V rail that has been designed to delivery more than ample power to dual graphics card systems, no matter if you use SLI or CrossFireX.
- Compliance with the latest Intel standard ATX 12V
- Single +12V rail for the most demanding SLI configuration
- High effciency design that meets 80 Plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multipe protection design (OVP/ UVP / OPP / OTP / SCP)
- High reliability (MTBF > 100,000)
- Double Layer EMI Filter restrains noise and injury to end-user
- Huge bulk capacitor for hold up time > 17ms at full load
- Integrating Active PFC with PWM combo controller not only make PFC higher than 0.99, but also raises efficiency
- Efficent transformer for reducing 5Bsb power loss when the system is at turn-off and sleep modes
- Five Year Warranty
Was £164.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
