Weekend Special - XFX GeForce 8800 GTX 768MB Extreme Edition @ £149.99+VAT (£176.24)
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
We have the an amazing weekend special offer for you on just one product and we refuse to be beaten so if you've seen an 8800 GTX in stock for less elsewhere let me know at [email protected] and I shall endeavour to undercut it:-
XFX GeForce 8800 GTX Extreme 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (PV-T80F-SHE9)
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 600MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1900MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- Supplied with DX10 version of Company of Heroes PC Game!
- 2yr Warranty with OcUK direct (For XFX warranty contact OcUK for RMA and we will endeavour to resolve your problem within 7 working days)
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Price: £149.99+VAT (£176.24 Inc. VAT)
BUY NOW!
This shipment has just arrived which is the last of XFX's stock or at least XFX UK's stock holding. This is a truly incredible deal and the stock is limited and as anyone will know this is an incredible price for this card and when its gone its gone. If you do find cheaper then email me at [email protected] where I shall endeavour to undercut anywhere else with product in stock.
OcUK is intending on leading the high-end graphics market by not only just bringing you the best deals/prices but backed up by good stock availability as well. :)
This sounds like a great deal Gibbo and doubt if it can be beat but am not sure what your original post actually means. On one hand it says thay you "refuse" to be beaten and on the other it says that you will "endevour" to undercut.
Clarification?
