** WELCOME MAGICOOL TO OCUK **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
I am delighted to introduce the MagiCool brand to you guys.
MagiCool offer a full range of copper radiators in a huge variety of sizes and cooling capacities.
Every MagiCool rad has low resistance and is a fantastic price/performance product at every size and price point.
MagiCool Copper Radiator - 140 mm @ £23.99 inc VAT
The copper fins are specially designed for silent fans, while the parallel coolant channels reduce liquid resistance to a minimum. On both sides of the radiator M3 threads are integrated to allow flexible fan mounting, on top chamber both G1/4" threads allow easy installation of all common fittings and barbs.
Specifications:-
- Dimensions: 183 x 29 x 142 mm (WxHxD)
- Material: copper (fins), brass (atria)
- Color: Black
- Compatibility: 1x 140mm fan
- Connectors: 2x G1 / 4
Only £23.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator - 280 mm @ £31.99 inc VAT
Specifications:-
- Dimensions: 323 x 29 x 142 mm (WxHxD)
- Color: Black
- Compatibility: 2x 140 mm fan
Only £31.99 inc VAT.
ORDER NOW
Magicool Copper Radiator - 360mm @ £67.99 inc VAT
Specifications:-
- Dimensions: 400 x 35 x 180 mm (W x H x D)
- Color: Black
- ~~Compatibility: 2x 180 mm fan
Only £67.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator - 420 mm @ £47.99 inc VAT
Specifications:-
- Dimensions: 463 x 29 x 142 mm (BxHxT)
- Color: Black
- Compatibility: 3x 140mm fan
Only £47.99 inc VAT.
ORDER NOW
Magicool Copper Radiator - 540mm @ £79.99 inc VAT
Specifications:-
- Dimensions: 580 x 35 x 180 mm (W x H x D)
- Color: Black
- Compatibility: 3x 180mm fan
Only £79.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator I - 120 mm @ £19.99 inc VAT
As a professional OEM manufacturer in Computer liquid cooling area, Magicool´s product line covers full range of liquid cooling components, including different size of heat exchangers, water tanks, pumps, cooling blocks and accessories. Excellent price-performance ratio and reliable quality make Magicool products unique.
With its compact design and excellent cooling performance, the Magicool radiators become top choice of water cooling users. The copper fins are specially designed for silent fans, while the parallel coolant channels reduce liquid resistance to a minimum. On both sides of the radiator M3 threads are integrated to allow flexible fan mounting, on top chamber both G1/4" threads allow easy installation of all common fittings and barbs.
Specifications:-
- Material: Copper fins
- Brass chambers
- Dimensions (LxWxH): 150 x 120 x 30mm
- Connectors: G1 / 4 (Standard)
- G3 / 8 1/2 (optional)
- Weight: about 350g
Only £19.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator II - 240 mm @ £28.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 276 x 120 x 30 mm
- Thread: 2x 1/4
- Weight: 650 g
Only £28.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator III - 360 mm @ £32.99 inc VAT
Specifications:-
- Dimensions: 394 x 30 x 124 mm (W x H x D)
- Dimensions: Weight: 900 g
- Color: Black
- Compatibility: 3x 120mm fans
Only £32.99 inc VAT.
ORDER NOW
MagiCool Copper Radiator I PRO - 120 mm @ £23.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 157 x 120 x 46mm
- Weight: about 650g
ORDER NOW
MagiCool Copper Radiator II PRO - 240 mm @ £32.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 315 x 120 x 30 mm
- Weight: 999g
ORDER NOW
MagiCool Copper Radiator III PRO - 360 mm @ £39.95 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 415 x 120 x 46 mm
- Weight: 1.5 kg
Only £39.95 inc VAT.
ORDER NOW
MagiCool Copper Radiator X90 - 92 mm @ £19.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 133 x 94 x 43mm
- Weight: about 450g
ORDER NOW
Magicool Copper Radiator 720 Hexa Xtreme @ £84.95 inc VAT
Proven quality and a perfect price-/ performance ratio is what makes this Magicool radiator great! The Magicool Hexa radiator offers not only excellent looks and great quality of manufacturing, the cooling performance is also truly exceptional. The copper fins are specially designed for super-silent fans (with low air flow). For a very low flow resistance the coolant channels are installed parallely.
The radiator has 2 G1/4" threads integrated, allowing installation of all common fittings
Specifications:-
- Dimensions: 395 x 45 x 240 mm (WxHxD)
- Color: Black
- Compatibility: 6x 120mm fan
Only £84.95 inc VAT.
ORDER NOW
MagiCool Copper Radiator Double Power - 80 mm @ £20.99 inc VAT
Specifications:-
- Brass chambers
- Dimensions (LxWxH): 90 x 190 x 46mm
- Weight: about 900g
Only £20.99 inc VAT.
ORDER NOW
MagiCool Deep Quiet 700 - DC12V Pumpe @ £39.95 inc VAT
Specifications:-
- Dimensions: 100 x 80 x 117mm (LxTxB)
- Weight: 650g
- Connection: 2x G1 / 4
- Inlet: 1x G1 / 4
- Pumping capacity: 700 l / h
- Lifting height: 1.7 m
- Input voltage: DC 12V
- Power: 10 Watts
- Life span: 50,000 hours
ORDER NOW
Any reviews on them? Are they a decent brand?
Prices are decent enough for thinking of going watercooling route.
next 10 days :)
Nice prices on the rads there!
they are entirely designed to fit a price performance bracket.
I have tried one and for the money, you can't really grumble. there of course is better options but as with anything: better = £££
The 360 I used performed fairly well, Build quality is nice and solid, fins are well spaced.
for people looking for a basic Radiator that does what it says on the tin, MagiCool fits the bill.
I have more radiator related news later as well :)
Where's the MagiCool rep to introduce themselves :D Are those the same guys that sell the sprays in Boots and Superdrugs for sunburn among other random items?
I see you added the MagiCool rads to the Value range of starter watercooling kits and makes perfect sense Richard :) People keep asking for cheaper options even though you changed the specs last month I think.
Good to have more options. Very hard to buy what you need for watercooling before someone snaps up the limited amount that comes in, I appreciate you ship in whatever you can in every month and thanks for trying to keep up with our high demands :D
OcUK dropped Black Ice rads recently, how's about revisiting stocking Alphacool again to support the other end of the price range? OcUK empty Alphacool page link :( http://www.overclockers.co.uk/mfrList.php?mfrid=300
I'm thinking the same thing. These prices seem designed to tempt more people into water cooling.
thats the plan. our lower end offerings have been neglected a little recently due to our close ties with other focus brands.
now we are improving this area, by including MagiCool for lower-mid range and Coolgate for upper midrange both at very attractive price points.
A lot of my existing vendors that we have close partnerships with have given me info that 2015 is the year they plan to release a host of new radiators too. so there will be plenty to choose from.
Alphacool isnt a brand we work with. XSPC do everything better for the same money and fully support the OCUK and Caseking group. I have worked closely with them for many years now and as a group we have no intention of introducing Alphacool to our offer.
Are those rad prices right :eek:
lol. that was my reaction when I saw the price list too :p
They look like good prices for people that are interested in watercooling but are on a budget, if my case was capable without modding and I wasn't so kack handed I might be tempted to have a go myself, would like to have my R9 290 under water :)
What is that pump mounted on the base of the res with? Hopefully rubber feet to make it quiet.
