Went over a pot hole and had a blowout - is my alloy wheel repairable?
29 Jun 2004
Hi,
I was driving down a country lane and there was a sudden unavoidable pot hole. Unfortunately the passenger side front wheel took the shock and deformed my wheel, which meant it was no longer air tight.
Is the alloy wheel repairable?
Thank you!
19 Oct 2002
Jupiter
If it's not particularly exotic I would just source a single replacement. It can be repaired but it'll always be weaker than an undamaged one.
OP
29 Jun 2004
That's a fair assessment.
Are you going to try and claim against the council for pothole damage?
Not really - I'm going to pay for my repairs and move on. If I do chase the council for compensation, then legally I will have to notify my insurance company. The council will explicitly ask me if I have asked my insurance company. Tbh I would rather not deal with the faff.
I'd be looking for a 'new' one
Is there anything to look out for? Or shall I just go for the cheapest matching alloy on ebay?
I’d get the suspension and alignment checked as well as replacing the wheel: that looks like a big enough hit to do more damage than just the wheel and tyre.
Good call! The car is new (i.e. second hand, recently purchased), and on budget tyres. I have new branded tyres incoming. When I get them fitted I'll also ask them to check the suspension and alignment.
14 Apr 2014
Sunny Sussex
It is worth doing if it's a more expensive repair - my father went over a pot hole and destroyed front and rear alloys and tyres. About £900 in repair, but got all of it back from the council. Though it took a while if I remember correctly...
1 Mar 2010
moreover .. find a local re-cycler ? postage will be the killer otherwise.
... can you actually claim for potholes on countryside roads ? a lot of the norfolk/cams you just have to be very attentive, know the roads,
otherwise you could kill a sidewall everyday.
Don
19 May 2012
Spalding, Lincolnshire
I'm in the minority but if there is somewhere local I'd at least see how much it would be to have it repaired.
No guarantee that a used one from eBay isn't going to have issues that you later discover (e.g. invisible cracks, or needs huge amount of weights to balance)
3 Jun 2012
Should be repairable.
But my question
How did you manage to hit a pothole so big to cause that? Too busy on your phone?
12 Jul 2007
South East
The council didn’t ask me anything about insurance when I claimed (successfully). It’s worth putting in a claim after you’ve assessed the full extent of the damage and had it sorted; it’s not your fault the roads are in such poor condition.
12 Mar 2008
West sussex
I've had similar repaired on my z4 coupe alloy.. Was £70 to do without paint, looked straight and balanced no problems.. drove another 2k miles on that without issues before I sold the car
18 Oct 2002
Not sure where the link between insurance and the council comes from. The process can take a while but they are both entirely independent.
