Hi !
I just got a seccond hand i7 920 CO/C1 and a P6T-SE for cheap
the board allows my LGA 775 Thermalright ultima-90i to be used
again, and this is good, as my case doesnt allow anything bigger
Opinions what 6x2 12 GB budget-ram to get is appriciated !!!
the overclock is NOT intended to be bleeding-edge, (video-rig)
Many of the kits i look at is NOT supported in the QVL
like this:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-008-PA
btw. would THAT kit be a good choice ? or a better OCZ kit ?
I am also afraid of the Vipers being to high for the cooler
thanks
thanks
