What are your temps?
CPU: AMD 955 BE(C2)@ 3.92GHz 1.52V
Cooling: Noctua DH14 with Artic Silver 5
Prime95 for 12 hours with a top temp of 52 degrees,
idle at 34 degrees. Room temp was about 22 degrees.
Gigabyte GA-MA790FX-UD5P, 955 BE(C2)@ 3.92GHz 1.52V, Geil Value 4GB DDR3-1600,
ATI 5850 1GB, CM90 II Advanced, 1TB Western Digital Caviar Black, 4 HDDs, XFX 850W
Black Edition, Asus Xonar Essence STX, Pinnacle PCTV 3010iX Dual Analogue + DVB-T.
cpu - i750 @ 4.2Ghz, 1.42Vcore: Idle 32-33C load 63C max.
GPU: GTX480 - 900MHz core, 2200 memory at 1.138Vcore - Idle 38C, load: 49-50C max.
Temps with Intel Burn Test and Furmark running simultaneously.
Watercooled passively, with heatkiller 3.0 block on the cpu and EK fullcover block on the 480 with a custom radiator. :)
CPU:
2600k @ 4.3ghz
Temp:
Idle 35,30,28,27 (temp for each core)(speedstep on)
Load 57,58,59,56 (5 minutes with p95)
Room temp: 22 ish
Cooling:
Megahalems Rev B with 1x Coolermaster 120mm SickleFlow
Case:
Haf X
