I've done this with a US soldering iron before now, it started glowing red hot!Just plug it in.. It'll juice faster with higher volts!
220 volts or 240 volts
I bought a juicer from the USA and now need to get it to work here in the UK. I heard you don't need a stepdown converter. Instead just a 240v plug adaptor, is this true?
If the juicer uses 1Kw, I have a feeling a step-down transformer is going to cost more than the juicer!So, after all the extensive research you apparently carried out before buying this 'Juicer' you didn't bother to check out the voltages and if the thing is compatible over here?
dvdbunny, the mind boggles! If you weren't so special you'd be special.
