What order shall I build my machine?
1 Sep 2007
Okay, started to build my pc, and now its got too cramped to do anything...
Want it to look neat - I have the antec 300, and it has some cable management stuff.
Want it to be easy!
Step by steps would be appreciated :)
Its me 1st build btw :)
Try and put as much behind the motherboard tray if you can.
Where in Leicester, I could help you :p
Heres mine what I did last week...
build it outside the case several times first to familiarize yourself with how everything goes together. its definately worth making sure your cables are the right length dont just use the ones supplied with the mobo/case this can do wonders for your cases tidy-ness and make it a pleasure to work on, rather than a chore
