Ive heard you can use Autoglym Intensive tar remover to get oily stains out of upholstery. It would depend on the amount spilt tho I'd imagine.
can it be taken out?
If so stick it in the bath with hot water and loads of washing liquid. Rinse through a very times to remove excess. Then leave in bath for a few hours with a proper grease/oil remover.
If so stick it in the bath with hot water and loads of washing liquid. Rinse through a few times to remove excess. Then leave in bath for a few hours with a proper grease/oil remover.
