What volts and temps are safe?
21 Sep 2010
Hi everyone, this is my first attemp at overclocking, could I have your comments about where I have got to and could you advise me on the maximum safe voltage for the CPU core and safe temperature I should use.
Intel i3 530
Asus P7H55
4gb Dominator 1600Mhz ram
Akasa Venom
Antec 300 case
BCLK 194
Multiplier 21
CPU Fixed Voltage 1.24375 V
CPU Frequency 4074 Mhz
Dram Frequency 776Mhz
QPI Frequency 4268 Mhz
Dram Voltage 1.650 V
Temperature 54 - 55C
Running Prime 95 Blend
I have not carried out an overnight test, but it runs stable for several hours.
Thanks for your help
46 fan ( and Vettel )
those temps are fine m8.
with the Vcore, just keep winding it back a notch until it becomes unstable then knock it back up a notch :)
