- 17 Jun 2009
Hello,
I have a pair of HIS 5870HD IColler Turbos running in XFire which are getting very very hot (92C at worst) under stress. I know its an airflow issue and that its common with XFire configs. Its exaserbated by the lowest PCIe slot having my Revodrive in it so neither card is drawing enough air even with a side fan blowing at them. When gaming it sounds like a helicopter is about to take off.
I am seriously considering watercooling. I have an H50 on my CPU but am pretty much a noob when it comes to watercooling so my questions are:
-What blocks fit my graphics cards? I tried HIS technical support but they had no idea. I have seen an article on the web suggesting just cooling the GPU and not the memory etc... is this not asking for trouble?
-Will I be able to add the CPU to the loop or will this require second loop?
-My Case is not at all optimised for watercooling (Antec p180) I planned to use an external radiator/reservoir combo are these any good or should I upgrade my case and go all internal?
Andrew
Andrew
