Quick question chaps,
Does a cylinder res need to be higher in the case than the pump? (If running as separate units?)
Ideally yes as it will make priming the pump loads easier
edit; I should say, the whole res doesn't need to be higher, just the top of the waterline - so level with or below, if that makes sense
They might be 2 gens old, but they sure do work well. There's no NVidia 6 series card that offers comparable performance for the price point. The 670, 680 and 690 are considerably faster, and significantly more NEW than a second hand GTX480 + the cost of a new waterblock.
I do agree that you'd be best served picking up a second hand waterblock, but if you do, make sure you buy NEW thermal pads that you need for that block.
You also don't need biocide with pre mix fluid, you already have the Ap121's so I'd stick with those on a controller rather than spend £50 on new fans.
I'd missed that - oh yeah if you've got the FT02 with AP's then use those doh! You'll need to keep them at 1000+ to stay level with FN's @ 700 though
IF you have the money go for one of the aquacomputer controllers, once programmed are near enough automatic, failing that go Lamptron
I'd recommend a fan controller with a WC setup anyhowIF you have the money go for one of the aquacomputer controllers, once programmed are near enough automatic, failing that go Lamptron
Ninja Edit: the RPM controllers you have are probably integrated to the case? Would suspect the fans are direct 3pin connectors, if they have in-line controls, set to 12v and plug into a fan controller and let that do the work![]()
a magicool 180x3 will be plenty..........
my case for the 3x180mm but the 2x180 would slot right in without penalty?This controller any good do you think?
http://www.overclockers.co.uk/showproduct.php?prodid=BB-000-LP&tool=3
Do you think that the 2x180mm would be good for CPU & GPU (GTX480).
The reason I ask is, I have to butcher, sorry I mean modmy case for the 3x180mm but the 2x180 would slot right in without penalty?
