What would I need to watercool a GTX480 (Reference) & My CPU (i7 3770K)?
Should all be MCP655's, the only 'different' ones you get afaik are the aquacomputer modded pumps that come with tacho signal cables and USB connectivity or something.
RJ confirmed for me today that the XSPC D5 is the MCP655 and it also has a tacho cable to plug into a fan header for monitoring :)
One last question guys, have a look here at a previous post in this thread I made: http://forums.overclockers.co.uk/showpost.php?p=22602498&postcount=46 bottom left corner in each pic where the round 'T' ball connector is, can I get some fitting that would allow me to use as a drain port, so it's closed off until I need it, maybe I could use a small length of pipe?? Any ideas, as this is the lowest point on my build :)
