- 12 Jun 2012
The overclock can be managed on both motherboards so why would you as a customer benefit from buying a pre-built system with a far more expensive board that runs at identical speeds?
You cant (well you can but you risk breaking your new hardware) overclock it further as that could result in instability etc and a lost system OC.
The systems are set up for both value and performance, theres no added value in replacing the board.
Hi Andrew,
Yes I completely get the value argument, no disputing that at all, particularly if the user is just going to take it out of the box and just run the thing.
But you said that swapping out the board can be more of an 'issue' and excuse me but I think that the words 'issue' and 'value' are mutually exclusive. To me an 'issue' is a problem, and quite a different aspect to just considering overal value.
So I guess what we really want to know are what are the issues? Technical, or just a 'pricing issue'?
