whats best 120mm fans for TRUE cpu cooler?
2 Feb 2008
Belfast
i just got this crazy fan from silenx thats 120mm but 38mm thick instead of 25mm. result 90CFM and only 18dBA at 1400 rpm!!! im gona make a wee post about it in a min and suggest ocuk get them in.
OP
5 Feb 2007
Inverness, highlands
my idle is 34c to 39c , depending if the patio door is open beside it load with i7 [email protected] on sensor test with real temp on heat up 100% 74c max with that all being after i resaeted the cooler and used arctic silver 5, so temps should lower aslight bit when bedded in
Caporegime
14 Dec 2005
armoy, n. ireland
Thats pretty good, id stick with what you have tbh, if your temps were getting to high or you couldnt stand loud noise id understand the need for new fans, but your current ones seem to be doing well.:)
