Nope. Enable the AHCI driver in the registry before you change the SATA mode of the boot drive. To do this, follow these steps:
Exit all Windows-based programs.
Click Start, type regedit in the Start Search box, and then press ENTER.
If you receive the User Account Control dialog box, click Continue.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
In the right pane, right-click Start in the Name column, and then click Modify.
In the Value data box, type 0, and then click OK.
On the File menu, click Exit to close Registry Editor.
Or, you need to enable AHCI on your Bios first before installing W7 for it to install the necessary drivers.
