1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
When money exceeds talent
Discussion in 'Motors' started by Dr Who, 7 Jan 2018.
  1. adolf hamster
    Sgarrista
    indeed, at least enough to give him time to think of things to do.
    manual/auto hit it into neutral, sequential you could go up the gears to give the engine a mechanical disadvantage.
    sounds to me like he pushed it too far, binned it and knows that by claiming stuck throttle this story will have dropped away by the time anyone has any proof to call him on it.
  2. Jono
    Man of Honour
    That was more the pedal getting stuck under poorly-fitted mats.
  3. theone8181
    Im sure they had a recall and it was something daft like a small shim that was missing.
  4. Nasher
    Capodecina
    The brakes won't beat the engine, you will just cook them if you press them at the same time as the throttle.
  5. Mercenary Keyboard Warrior
    Capodecina
    I had similar, first car.
    A can of deicer that was supposed to be in the rear footwell ended up in the front
    Went behind the brake pedal. Luckily handbrake and manual meant all ended well, but when you go to press a pedal and it doesn't work as intended its a heart in mount moment!
  6. BigDannyO
    Wise Guy
  7. Dr Who
    Sgarrista
  8. Yaayuh!
    Capodecina
    How incredibly stupid/lucky of you.
  9. Haze
    Mobster
    Makes my mind boggle, people that have stuff rolling about in their cars loose
  10. BigDannyO
    Wise Guy
    In that video it shows the car slowing quite effectively when he presses the brake. He claims that the car won't stop but it sure looks to me like it could.
    If I can refer you back the the Car & Driver and Revisionist links where they absolutely did stop.
    "We included the powerful Roush Mustang to test—in the extreme—the theory that “brakes are stronger than the engine.” From 70 mph, the Roush’s brakes were still resolutely king even though a pinned throttle added 80 feet to its stopping distance. However, from 100 mph, it wasn’t clear from behind the wheel that the Mustang was going to stop. But after 903 feet—almost three times longer than normal—the 540-hp supercharged Roush finally did succumb, chugging to a stop in a puff of brake smoke."
  11. Mercenary Keyboard Warrior
    Capodecina
    Indeed.
    Was odd as this happened in the summer. The can had been in there from the previous winter.
    I think a passenger had pushed in under where it wouldn't have gone normally probably with a foot.
    I returned it into the back but in a much safer place, the rear passenger footwell ;)
  12. Mercenary Keyboard Warrior
    Capodecina
    Cripes that is some braking distance. Makes you think if the brakes are not in very good condition, such as heading towards replacement due to wear if they would function well enough to actually stop it.
  13. carrot1401
    Mobster
  14. BigDannyO
    Wise Guy
    I think the brakes should always win. For the engine to win would imply that the car can accelerate more quickly than it can decelerate, and I'm pretty sure there isn't a car that can do that.
  15. adolf hamster
    Sgarrista
    i reckon it's more a gearing thing, in lower gears the engine might just have a chance, hence the thing to do is to get it into a higher gear to reduce the applied wheel torque. (plus if the gearbox has a safety net to stop you dropping into too low a gear for the speed then it'll still let you try and lug 6th at lower speeds)
  16. Lashout_UK
    Capodecina
    At least that one was complete and utter mechanical failure. No way around that!
  17. AHarvey
    Capodecina
    My old boss bought an Audi R8 because he likes showing how rich he is... It's never been above 70mph.
    It's all about the status symbol
  18. Dr Who
    Sgarrista
    EVENTUALLY they will win, but will you survive the slowing process with 562bhp fighting you when it happens at your usual braking point? This guy wasn't on a straight airfield/road he was braking into a roundabout, it wasn't a hypothetical "can the brakes eventually win" it was can they stop you BEFORE you crash, and in this scenario, they wouldn't (and may not have actually according to the driver). The point was shown in the video I linked that it did slow you, but not effectively and there are far better ways to stop the car quickly.
  19. theone8181
    A hedge and bins apparently:D.
  20. Yaayuh!
    Capodecina
    1.Brake
    2.Put in neutral
    3.Kill the ignition
    Generally speaking. Though killing ignition will also kill any electronic aids I assume.
    On a bike you can just hit the kill switch, brake and pray.
