- 2 Oct 2008
Read other, similar threads and you'll be fine (your wallet not so much though )Just about to do my own first custom loop and it's a mine field with all the different things you need
Tell me about it.
I'm looking at gpu only then cpu later on.
Problem is I'm not sure about trusting used parts incase of any issues!
He isn't using any corrosion inhibitor so will have to change the fluid more often, if you use quality fluid it will last until it's time to change CPU/GPU anyway.Sadly I'm too lazy for regular maintenance on stuff like that especially if it needs stripping down and draining lol.
I was referencing an earlier post where I was running 2 systems one with de-ionised from halfords (because I was impatient) and the other with an additive - the one with just de-ionised was in quite a state when I pulled it apart a couple of years or so later. Would have been less of a problem if I had any kind of maintenance schedule for it.
Dear manufacturer, can I use cheap deionised water out of Halfords or do I need to buy your expensive premixed solution?
One guess to what the answer is going to be
I ran a loop for about a year with water out my kitchen tap. It did look a bit funky come the end but no issues with either of the blocks afterwards.
Halfrouds £5/5L wilkos £1/1L German Swedish French £3.??/5L eurocarparts £?/5 anywhere that sells car batteriesI've looked everywhere locally, from supermarkets, to Halfords and chemists and can't find any!!!
Yeah other people’s crapMy Dad works at GSK and he can get pure H2O bottled to bring home. Its very useful.
I also tried drinking some once. It was almost completely tasteless. So the taste of tap water is just the crap thats in it...
